Tricolore
Tricolore's Achievements
  1. I know this is an old thread but I figure if I can help someone decide on this Clear Choice so here goes: I used chlorine and bromides for the first year that I had my spa. I ended up spending more time each week cleaning my spa than I did sitting in it. I started regretting that I bought a spa. I figured there had to be something better to clean a spa so I did a web search and found Clear Choice. That was 6 years ago and I haven't looked back. I don't care what the "scientists" on this web site think. This stuff works. I couldn't believe how well it works. I put 12 drops of enzymes in my spa and spray off the filters once a week. This takes all of 5-10 minutes. My water is ALWAYS crystal clear, no smell, no scum and no health problems. You can tell if bacteria is starting to form by rubbing your hand on the side of the inside of the spa while you're in it. If it feels a bit slick (nothing gross) you simply add extra drops and it goes away. Next week I will be changing the water...after one year! It looks exactly the same as the day I filled up the tub. There has been some residual calcium build-up in the pipes, but I use a prep prior to each tub refill to get that stuff out (not a hard calcium; soft). I wonder why Home Depot and other stores don't carry this stuff. I turned on two other spa users to it. They also have been using it for years w/o a problem. Don't know how it works; it just does. Use it, you won't regret it and if you don't like it, simply switch back.
