I had noticed a loss of water for last two seasons, and noticably last Winter where I lost almost 3 feet of water. So, this past Summer I had the Man out to find and fix the leak, the one he found on the bottom slope seem to be too small to be the real problem, but I'm not the expert. So, now 6 mos later, I'm still seeing water loss with the pool closed up...probably several inchs a week. So, I'm guessing I have a main drain problem as the water is below the return lines and the Man didn't find any other leaks around the pool.
So, with the water level lower, I can try and get a dye test to see if somethiing gets drawn into the main drain. then I can try and cover the drain to plug it and see if level doesn't drop. I see that fix-a-leak can be applied though not sure how effective it would be getting to the actual leak without and suction on the line. And, I see we can choose to plug the main drain.
Curious what comments the community has as I look to open the pool in the next 30 days.
