I was receiving several error codes from my unit about a year ago (don’t remember them now) so I did some research online and realized I probably had a bad sensor. Ordered a new one (part # R0452500) and had our local pool service install it. Everything worked great and the system was again making chlorine. I decided to clean my cell last week by dipping it in a water and muriatic acid mix for 30 minutes. All the scale came off no problem. I re-installed the unit and now I don’t get any error codes – just “no flow”. I thought the pool might be low on salt so I took a sample to our local pool supply company. They gave me a reading of about 2.2 gpl. I was told I needed to add two 40 lb. bags to bring it to about 3.0 gpl (I have an 23,000 gallon pool). When I added the salt, the sensor gave me an error code of 145 – meaning too much salt. I took another sample in and I’m actually right where I need to be at 3.0 gpl. Now the sensor outputs “no flow” with no included error codes. I unplugged the sensor, cleaned the three sensor pads, unplugged the small board, checked for loose wires, plugged it back in. Power cycled the cell, and bam! I was back to making chlorine! However, after about 5 minutes, the sensor went back to “no flow” which means no chlorine. I’ve only had this damn sensor for 9 months! Do I need a new one again. What could it be? I would appreciate any help. Thanks.
