Hi everybody, I'm been lurking and searching here for the last several weeks since I acquired an old hot tub off Craigslist for free.
Here is all the info I've gleaned off of it: It's a Discovery Spa SL800 (Can't find that make anywhere!)
It has a Balboa ZX1000 control board
And this Topside controller:
The main recirc pump works great, both speeds. The secondary pump and blower don't work (not a problem right now.)
The heater tests out great, and does indeed heat the water.
When I first got it, I couldn't get it off ECON mode and thus couldn't get the water temp above 97F. But with enough button mashing, I found out how to turn that "feature" off.
It will often stop running and display FLO, but if I mash the Jets button enough, it'll start back up again. I know it's trying to tell me that the flow switch is malfunctioning, but I've tested it with my meter, and it seems to be working fine.
The other day, I came home and checked on it, and it displayed ILOC and nothing would work. I looked up that code, and found that it is an interlock for an open door panel or over-temp. There is no door-panel sensor/switch, so I guess I have to assume that it's an over-temp issue. I only set my temp to 102F, so I can't imagine that occurring unless the pump didn't start for some reason. Anyway, I cycled the breaker, and now we're back in business.
TODAY, I went in the tub, and the normal FLO was displaying, but when I mashed the buttons, the pump started, and then SN1 appeared on the display. Dang... So, I looked THAT up, and it seems that code is for Hi-Limit sensor malfunction. WTF... I'm not sure how to test the sensor (what the resistance range should be, etc)
Anyway, Sorry for the long post, but I was thinking that perhaps somebody might be able to shed some light on these issues. Could all of this indicate a bad board?
Thanks for any help you can provide. :-) DAN
