I have a box which I purchased at Menards which has 1 single 50 amp GFCI breaker in it. I have the little jumpers set correctly, but the panel instructions say there are two jumpers required on the wiring terminal. There is one between 5 and 6, and there appears to be one between 7, and the terminla next to it, which is not numbered. This may not be a jumper, as it looks like it is not remaoveable. I just checked the tub (I had it set all the way up), and the heater light is ff, and the thermometer reads 108. That water is way too ot now, and I turned it back down. Looks like I just got impatient with it. Will the heater kick back on, or will it need to be reset.
I have this box: http://www.toolking....CFelFMgodglIAqQ
As I look deeper into this, it appears as though I have the wrong box. Did I waste a lot of time and money on this so far, or am I ok. It looks like one of the terminals that should have a hot wire running to it, does not have one.
My water is hot, the circ pump is circulating, the light works and the jets all work. What am I not getting with that one wire seemingly not conected?
If I need the other box (with two seperate breakers), can I add individual wires to the existing 6/3 I already installed?
Edit #5: Do you know what what each terminal (1-7) powers in the tub?
