fibercoug
  • Content Count
    53
1 Neutral
About fibercoug
    Spa Savant
1,885 profile views
  1. I am glad it was easily "repairable". 😂
  2. Does anyone know which wire is hot and which is neutral on a Del Eclipse ozonator or if it even matters? I need to switch it to a regular 3 prong plug. Thanks
  3. I would still contact backyardplus. They may have a solution for you. Is your tub the one with the control panel on top or on the side? What is the serial number?
  4. Check Backyardplus.com. They have been very helpful when I was looking for parts for my 2001 Grandee.
  5. Last summer I purchased a cover from BeyondNice for my Hot Springs Grandee. I am more than satisfied with it. The factory is in Florida and it had to be shipped across the country to Washington State. It arrived in perfect condition. So I would say you can purchase from someone other than Hot Springs with good results.
  6. I am surprised the tub is warming up much at all without a cover in those outside temps. That is one hard working heater. I would hate to see your electricity bill.
  7. Try disconnecting the ozonator. It may be putting out excessive EMI that can cause tripping of the GFCI. I had the same problem with a Hot Springs spa.
  8. Thank you. That is what I thought. So I will wire my ozonator to be separate from my control board. Something I should have done long ago.
  9. I am trying to determine if my Hot Springs Grandee runs the ozonator 24/7. The circulation pump runs 24/7 but does the ozonator do the same? I want to rewire my ozonator to be separate from my control board. That would mean the ozonator would run 24/7 also. Is there an problems with doing that?
  10. Try disconnecting the ozonator. Some of them emit excess EMI and affect the control board. I have had that happen to me.
  11. Grandee made in the first quarter of 2000, #1506.
  12. This is the bleed line from the elbow just off the circulation pump to the filter compartment. Since it is on the output side of the pump plugging it will divert more water to the heaters. Filters are clean. I am more interested in what the purpose of this bleed line is.
  13. What is the purpose of the bypass hose coming off the circulation pump? I believe my pump is getting weak (it is the original one) and I would like to plug the bypass to get more flow into the heater until I get a replacement pump. Will this cause any problems?
  14. I have been using the Del APG unit for some time now and it has been working perfectly. I had problems with other ozone generators interfering with my control board and the APG unit does not do that. I would recommend it. Also Del's customer service has been fantastic. You can check out my other posts and see what I went through and how Del would not give up until I was happy.
