Hi everyone, I've spoke with a few builders in my area and have been researching as much as I can about pools however I really don't know anything about them so I was hoping I could keep this thread going for a while and throw some questions out to y'all. One builder perfers steel walls and his price was higher than the other two by $7,000 - $10,000 although he included a few more items valued aroud $2,500. We didn't seem to hit it off very well so I'm inclined not to use him, but still open. The other two builders have great references and are larger companies, one is very local to my area. Both of these builders perfer poly walled pools. One uses Prestige which he explains is a Pacific pool. Looking at Pacifics web site, they seem to have very nice panels with alot of reinforcement. The other builder gives me a choice of Hydra, Matrix or Caravelle walls. The Matrix walls appear to be really well made, again with alot of reinforcement. Both the Pacific and Matrix appear to use different panels for the skimmer. The Hydra and Caravelle look similar and don't seem to have as much reinforcement and appears you use the same panel for the skimmer, it's just cut to fit. Is this correct? Does anyone have any positives or negatives about any of these pools?
The pool size I'm looking at is a medium to large L
Builder #1 recommends this equipment for a 42'x18'x26'
2" vermiculite floor
concrete collar around base of walls
1 1/2" PVC ( I asked for 2" and he said "no problem")
Hayward s-244t 24" sand filter
Hayward sp-2607 pump 3/4hp.
2 Hayward wall fittings
2 Hayward eyeball fittings
2 Hayward skimmers
He recommended against a bottom drain but said he would install it if I wanted
Pacific poly steps
my choice of Premier or Merlin liner
Builder 2 recommends this equipment for a 40'x20'x30'
2" cement and Vermiculite floor
concrete footing around walls
2"PVC
Hayward s270T2 sand filter
Hayward Tri-star pump 1h.p.
2 main drains
3 returns
2 skimmers
Pacific poly steps
my choice of Kafko liner
3 way valve for flow control between main drains and skimmer
Please give me your thoughts on this equipment (not a brand war, but just if anything looks really off), pointers or ask me any questions, Thanks.
