I acquired a 2005 Hot Springs Vista last week. It is in fantastic shape, and worked great when I was looking at it. All of the features operated flawlessly. One week later it is finally sitting on my deck and filled with water, but the only things working are the circ pump and led lights. The main panel and aux panel are both getting power, but I can't turn on the main jets and there's no heat.
I had the wiring and hook-up done by a licensed electrician, so I don't assume there's a problem there. The wires hooked up in the spa pack were installed by the original owner (he disconnected the flex conduit from his sub panel, and left the other end connected to spa. But I don't see any problems there either.
I have scoured the web looking for some insight, but unlike finding how to change axle seals on a jeep, its a lot harder to find information on hot springs problems! I have re-set the spa numerous times by turning off the breakers for 10 minutes. I also removed the filters, and opened both drainage ports a little to help remove air bubbles.
The picture shows the current lights that are lit on the circuit board. The top one (LIM OK) is green, heater is red, and then down below to the left there is a red light that turns on when pushing the jet buttons, there is an audible click, but no jets.
Any help you can offer would be a blessing!
