Brian T
Content Count
29 -
0 NeutralAbout Brian T
Rank
Junior Member
Of course that did not work. Had them come out and flush the lines through hydrant. Still brown. Ordered some stuff to clear water and will run through old filter. I bought a new one to put in when I get clear water.
Ran cleaner through last night. Some funky stuff came out. Have hose filter coming today. Going to give that a shot. Have new filter coming Monday. That new pump got me fixed up. Ready to use this thing again. Maybe get another 20 years out of it.
We have been dealing with brown water in out Subdivision for several months now. Have to call city and have them flush lines to get clear water for hot tub. This the second time now I have filled with brown water and now my filter is getting clogged. What the best way to get this out of filter?
2002 Sundance Cameo cirulation pump turning off and on
Brian T replied to Brian T's topic in Portable Hot Tubs & Spas
Man my hands frozen. Got it winterized. Will order new pump. That thing only about 2 yo. That really threw me hearing that relay and pump turning off and on about the same time and pumping good when it was on. Thanks CanadianSpaTech. Would prefer to have non-smart pump but guess order same one. -
That smart part of the pump is the problem I would guess. Pumps fine when it runs. -
Thanks for taking time. This been a bad week. Decided to retire and first week of year new dryer, emergency dog visit, have to get couple crowns, hot tub and bad week for mom. Going to winterize tomorrow and order new pump. -
The filters have been removed. I put the E10 in last time. I can not see any bubbles in the line but for the couple seconds when it shoots water in the tub there are bubbles. I had also used water hose yesterday to try squirt water in. After ten times it keeps going. The light comes on for a short time. -
I guess that the heater relay turning off and on. Voltage to pump from black wire to ground 120v and white to ground 120v black to white 240. Guess pump bad. -
I so sorry did did not read your question right. It been a day dealing with my mom alzheimer. It flashing back and forth. -
Something telling the relay for the pump to constantly turn on and off. I checked the flow switch and it OK. The pump hardly stays on long enough to get water flowing. I have tech coming next week. He said something about low voltage and could be the board. -
I replaced it few years ago. The relay is turning off and on to the pump. Not sure it the pump. -
Service tech had me replace the breaker since it had been tripped so many times. He set the pump to run 24 hours. It only trips about the third or fourth time the pump tries to come on. Once it is on the 24 hour cycle it probably won't trip now. Will see how it goes.
I have a tech coming out Friday. I really think I managed to get two bad pumps or pump not compatible. Both of them had a service sticker on them that I thought was strange. Tech had me unhook pump and turn off and on with the temperature like I was getting it to trip before. Did not trip. Maybe this new pumps need to be hooked to a system that uses neutral wire. Hope tech gets figured out.
