I did all the tests in the kit but I am having a hard time understanding the FC test.
Step two says to "2. Add 2 dippers R-0870. Swirl until dissolved. If free chlorine is present, sample will turn pink." Is that two dippers at 25ml or at 10 ml ? Is that 2 level dippers?
Thanks
Test reads
Chlorine (Free, Combined) Test
1. Rinse and fill large comparator tube to desired mark with water to be tested.
NOTE: For 1 drop = 0.2 ppm, use 25 mL sample. For 1 drop = 0.5 ppm, use 10 mL sample.
NOTE: If pink color disappears, add R-0870 until color turns pink.
3. Add R-0871 dropwise, swirling and counting after each drop, until color changes from pink to
colorless.
4. Multiply drops in Step 3 by drop equivalence (Step 1). Record as parts per million (ppm) free chlorine
(FC).
5. Add 5 drops R-0003. Swirl to mix. If combined chlorine is present, sample will turn pink.
6. Add R-0871 dropwise, swirling and counting after each drop, until color changes from pink
to colorless.
7. Multiply drops in Step 6 by drop equivalence (Step 1). Record as ppm combined chlorine (CC).
