Wizzard of spas
Content Count
48 -
0 NeutralAbout Wizzard of spas
Rank
Junior Member
Baquacil Conversion Need Help!
Wizzard of spas replied to tablpa's topic in Swimming Pool Water Chemistry
You do not have to drain the pool, there is a neturalizer you can add to eliminate your bioguanide. Just make sure the pool is neturalized before you convert over.- 5 replies
- conversion
- baquacil
Please Help, My Bromine Level Keeps Dropping
Wizzard of spas replied to meinpa's topic in Swimming Pool Water Chemistry
Why are you adding bromine to a pool with so much clorine? come on? forget the bromine, and add some cyniric acid to keep the chlorine in the pool, and you are done, go swim. -
Attempting A Do-It-Yourself Leak Fix In Pipe
Wizzard of spas replied to DougB's topic in All Swimming Pools Types
Really looks like an older system, Great photos, however really hard to follow. Best bet is to have a professional technician come out and assess the situation, any Tech worth his salt will have an answer for you in 5 mins. -
OK, my turn to learn something. The customer says he is getting too much pressure to the heat pump. A heater bypass rather than downsizing the pump, would be my suggestion. In the owners manual there should be a diagram for a heater bypass; "Required" if the Flow, GPM is above a certain number, An easy way to determin this, is to install a simple flo-meter on the line going to the heater. If you have a flo-meter, and a bypass valve installed, which is easy, and inexpensive, this eliminates any question of pressure or flo issues to the heater. Once you have determined that the flo rate th
There is only one place for the water to come from. There is a leak in the heat exchanger; could be just a pin hole. Thanks for the input, I have edited my post. I'll do better next time. Scott makes a good point. The leak does get bigger when the heater is on and heating.
Cause Of Failure On Max-E-Therm Control Board
Wizzard of spas replied to dnspade's topic in All Swimming Pools Types
Push on the conecton works, let off the pressure fails, hmmm? probly need a new pump. just kidding. Give Scott a call. -
If you live under pine trees? every day! Can we have a few situation perameters? What are the enviromental conditions, and what is the bather load. Public pools require 24/7 maintenance with water testing ever 4 hours. Are you in the country, in the desert,in the city, in the open, under elm or oak trees trees? Not all pool enviroments are the same. Are you indoors, or out of doors? Give us a few pool paramaters, and we can beter help you dial this in. How many people use this pool? 2 or 200? very important info.. help us help you. PS Im inOregon, Everyone with inground pool has hea
Is the pump leaking? If pump is not leaking, at the point where the pump joins the moter then you are good. Never dry run a pool, or spa pump. you will burn up the shaft seals, and even possibly melt the pump. Never ever run a pump dry, you wil destroy the pump (wet end). Most NOISE in pumps comes from dry bearings. What happens in most cases is,... The shaft seals begin leaking, water runs own the shaft to the forward bearings. watr gets into the bearings and drys them out, they corode, and wear faster exposed to water. the motor shaft, also exposed to water rusts, and enlarges du to oxid
It's a leak in the heat exchanger. It's not that hard to replace. Perhaps two hours. i will now Chill. sry guys carried away.
Intellitouch System Cycles Pump Every 15 Minutes
Wizzard of spas replied to Wotan's topic in All Swimming Pools Types
I would break out the manal, and look at the possibilities of programing. the pump is doing what it is told to do. I would like to follow up on this. let me know what you find out. Many controll products have default filtration cycles of example 2 hours every 12 hours,... Balboa for example. Depending on bather load these perameters can be changed. Do you have the owners manual, and have you read it? -
This is a very common problem in new pool installs by non professionals. did you forget to install the HEATER bypas with control valve? Yes you did! plumb in a straight heater bypass with a control valve. regulate the flow to the heater, ,Mark the posistion of the bypass valve and tell everyon not to mess with this valve. The water coming out of the heater should be only 10 degrees hotter than the water going in. you adjust the pressure to the heatrer by watching the gauge on the filter. wide open is normal pressure to the filter; crank the bypass valve open closed untill the filter pressure
New Light Wont Fit Into Niche
Wizzard of spas replied to pulleyman123's topic in All Swimming Pools Types
Most pool lights anticipate the replacement of the bulb. Yes it is a sealed unit. Unscrew the unit from the back, replace the bulb, and reseal the unit, JOB WELL DONE. If your new light housing does not fit the nitch, Ouch! Most manufacturers have upgrades for discontinued products that will fit. If you can fit the light into the nitch, and secure it with one screw leaving only a small gap then it is what it is. The nitch is always full of water in any case, no big deal. Give me the model number of the origional, or the name, or even post a picturer. I can easy help you with this one. p -
This device is used to presure test the lines in a swimming pool when checking the lines for leaks. You place the device into the line, turn the butterfly untill you have a positive seal; pressurize the line with an air compressor to 25 PSI. and watch your pressure gague needle to see if the pressure drops. If the Pressure drops after 24 hours,... You have a leak. This is a Pressure testing device. That sucker is band new too, Can I have it?
