I just had a used Aries tub delivered by a friend of mine. He removed it from a house a few months back and it has been sitting under a cover in the back yard since then. It has a few minor leaks, but nothing I am too concerned about there. They all look fairly minor and easy to seal up.
When I went to put power to it, nothing. The gfci breaker keeps tripping. It has a built in panel with a built in gfci breaker. If you push in the gfci breaker on the panel, it will run for a second, then shut off. The weird part is when I check the voltage at the connection, one of the legs is only showing 60v. If I check it for 240v, it also shows 60v. If I check the other leg by itself, it shows the full 120v. When I pull the wires, it reads correctly at 120v per leg and 240v combined.
My friend is telling me it is being caused by a faulty gfci breaker in the panel. He is recommending bypassing it and putting a box in outside the tub. I had already planned on getting an external gfci disconnect, but I also know that you cannot have 2 of them in a circuit. I am not an electrician, but I am pretty handy and I have done enough electrical work in my life to know how to do basic stuff, including working with 240v. I have just never really worked with hot tubs. I know how to do everything from soldering small components such as caps and resistors on pcb's up to wiring up three phase industrial machines like cnc mills and lathes. I just do not know what to do with stuff like this when it doesn't work. I figure it is better to ask someone who does, especially when it comes to water and electricity.
Any recommendations here? Thanks in advance.
Edit: The control panel is an Aries A72-E if that makes any difference.
