cdc1982
cdc1982's Achievements
  1. Thank you for your help. We found out that one pole on GFI was malfunctioning and was not allowing 240V to the spa pack.
  2. How much voltage to the common? and if you got some more info on what is going on with the tub that might help as well. The tub is not doing anything and there is 125 volts on the common wire at the pump. It's a Gecko S Class pack and a Waterway 56 2-speed pump. It is a 240 volt system. The power supply to the spa pack tests correctly. When I switch on the breaker I can hear the relay click on but nothing happens. The pump and spa pack are new, the only thing that was not replaced is the top side controller. Any help is appreciated.
  3. My hot tub doesn't work. I replaced the pump and spa pack. The new spa pack is doing the same as the old one. The common wire to the pump has voltage but shouldn't. Can anyone help?
