First off thank you all for your help and advice on this board! It is sincerely appreciated! I purchased a used spa from a friend which is a 2005 Jacuzzi brand J355. It has two pumps (two speed low/high "pump #1" Emerson T55MWCCE-1208) and a (single high speed pump which is "pump #2" Emerson T55SWBNC-999). Pump 1 operates normally at low speed, circulating the water, and you can see/feel it coming out of the jets as expected. As soon as you hit the button a second time to switch Pump#1 in to high speed, all circulation in the hot tub appears to stop. I can still see the motor turning, it does not slow down or lock up, but immediately the rush of water through the wet end cannot be heard, and all there is a low hum noise (although as I mentioned, I can visually observe the motor still turning). I went through the steps to make sure there is no air lock, although I would think that type of condition would demonstrate itself in both low/high pump speeds?
In addition, both pumps are leaking slightly from outer screw cover of the wet ends. Any advice on part numbers to replace the wet ends would also be greatly appreciated! Thank you.
Steve
