GKL
36 -
About GKL
- Birthday 09/18/1951
Contact Methods
http://
Baltimore, Md.
Real Estate
GKL's Achievements
YES, I've wsed it since Dec '06 when I first filled, I am just getting ready to dump & refill after 7 months. Water has been nicely balanced, clear and I have not developed any "itch" or infections as many on here proclaim, I use the tub avg 5-6 times a week for 20-45 minutes each soak. My longer stay is due to the tub temp at 99 degrees vs 103+. I even cut the ensyme dose in half (used the bottle for 2 filter changes) I believe you can also purchase at ebay.
Hey Trigger, Jim has been the only one to post anything with regards to my question. You only used it as a means to get your dig in at JIM and still did not answer the topic question. SO, THANK YOU JIM. GREG!
Are the jets producing water? If so your pump is primed. I can't imagine how the temp. would get to the desired setting if water wasn't passing thru the heater EXCEPT "the setting" does not show the water temp. in ALL spas, this might be your DESIRED setting you are reading NOT the water temp. (Tried feeling the water?) The good thing is that if water isn't passing thru the heater (pump not primed) the heater SHOULD not be staying ON which would burn it out, however depending how long you are leaving the pump motor "run" might damage the PUMP unit. If water is flowing from all of the tub jets, try cycling the motor between speeds OFF, LOW, HIGH. If water is not coming from the jets, shut the power off and open the panel closest to the pump. Then loosen the union/fitting (big nut on top of the pump motor about 3-4" in diameter) about 1/4 of a turn or until you hear air escaping, then a few drops of water. Tighten down securely and RE-BOOT & re program spa pac as below. Cut the power from the GFCI/ circuit breaker and wait 5 minutes and (re boot) turn power back on, re-program the spa pac for time, filtration time, desired water temp. and duration of filtration. Make sure it is actually running ALL the time and not JUST WHEN YOU GO LOOK AT IT. Also, be sure all of the shell covers are back in place. There are alot of posters smarter than me on here but since I didn't see any one giving any definitive help I thru in my thoughts- GOOD LUCK. Let us know what you find. GREG!
I've not seen any discussion (here) on the methods used in cleaning of spa filters? I just changed mine out with new and wanted to know if the use of any special cleaner is worth the cost, or is there a more economical solution. (Muriatic acid?) If there is a good product, please post and suggest a location to purchase. Also is it a good idea to keep the ones I just took out soaking in water or other solution? GREG!
I've been cautioned to remove any added insulation in the summer months to prevent heat build-up and possible damage to the pump motors. GREG! I've been cautioned to remove any added insulation in the summer months to prevent heat build-up and possible damage to the pump motors. GREG!
I too was planning to add insullation but first I decided to monitor the temperature outside the tub and inside. I have found that the inside stays at 40-50 degrees above the inside. In talking with the service dept at GCS about the frequency in which the spa pack runs a temp test of the water its hourly for 3 minutes. If the water temp has dropped the heater kicks in to heat to temp setting. With the pump running hourly for 3 minutes plus the regular filter cycle-do the math. Electrical consumption may be coming from the pre-programed cycling of the pump. I've cut my filtering down to 1 hour 2 times a day and water is fine. A nother alternative would be to install a 240V timer to limit the number of hourly programed temp checks. The only problem is the spa pack re-sets to 95degrees each time electrical current is cut off. Also the service dept cautioned me about adding insullation in that it should be removed in the summer to prevent high temps that could limit the life of the motors. GREG!
Gulf Coast Spas have (and I guess other manufactures have the same) a winter freeze sensor. If the temp. falls below 41 or 45 deg. inside the cabinet the spa pac will cycle on every hour for a 24 hour cycle to monitor the water temp causing the pump to run for 15-20 minutes each hour. So if the temp doesnt change inside the cabinet the winter freeze cycle will continue. I've asked GC service about changing the temp and they said they thought it was not changable. I did speak with Ken S from Tatum a few weeks ago and I thought for sure HE said the temp could be changed. I've been planning on putting a dual thermometer to measure high & low temps in cab & outside but guess I'm waiting for warmer weather or my 1st bill. If the spa is getting below 41-45 deg. under the cabinet with all the heat generating stuff under there then it clearly isn't insullated well or there is a hole some where letting cold in & hot out. I've been keeping mine at 99 so I can stay init for 1-2 hours and with 20-25 degree weather, cover off temp might drop 1-2 degrees and usually doesn't kick on unless it drops 3 degrees. Heated up about 4-5 degrees per hour on initial fill w/ 55 degree water 350 gallons with cover off.
Hey Smilinbare, take it like A MAN. If you screw up let ALL know, you might save someone else some trouble down the road. I've not seen anyone being put down for being honest in their efforts for knowledge. There do appear to be some that are hard headed and not willing to admit their F--- UP's. BE A MAN, no body is going to hit you. GREG!
http://i146.photobucket.com/albums/r261/gr...terSPA/Tub1.jpg http://i146.photobucket.com/albums/r261/gr...terSPA/Tub2.jpg http://i146.photobucket.com/albums/r261/gr...PA/TunUnder.jpg http://i146.photobucket.com/albums/r261/gr...erSPA/Steam.jpg http://i146.photobucket.com/albums/r261/gr...PA/Downshot.jpg
Substitute Chemicals For The Arctic Line.
GKL replied to klt1200's topic in Portable Hot Tubs & Spas
I was going with the traditional Bromine then found several good posts about ecoONE on here. Natural enzymes with small amount of bromine, longer life of water, less bounce in chemicals and easy maintenance. Turns out that the start-up kit that came w/ my spa is the same thing, just marketed under a different name. Check out some of the post.. key in "ecoone" -
DAY 2 Everything seams to be working perfectly, heating properly, pump cycling on schedule. Didn’t look at light… tomorrow. Around noon with water temp at 90 degrees: Added 4oz AquaClara Pure Sustain to 350 gal. (Directions recommend 8 oz for 550 gal) 1 oz AquaClara Enzyme filter boost (recommended dosage) 2 Tabs AquaClara (bromine sanitizer) in filter area Activated pump to high (auto shut down after 20 minutes) and raised temp to 95 About 3pm activated pump to high, raised temp to 99 First dip was about 9pm. Pump was in auto filter mode until 10PM (as was I) when it cycled off. Not quit as happy as I thought. Seating, jet pressure and water circulation were all-good. My only concern is even with my water slightly higher than it should be I would like to have more depth or higher water level when sitting in the seats. The contoured lounger gives me the desired water level missing from the std. seats and holds me in nicely even with water & air jets on full (I floated out of my old lounger). Being 5’10” I can lounge nicely with jets on desired areas as could someone 6’10”. One whirly jet seams to be stuck, but all others seam to be fine. Nice to be able to control each individual jet (on/off), bubbler jets works a lot nicer and than my last tub (simple had holes drilled in the seats) and the warm air is a pleasure and energy saver (not cooling down tub water)
I'm not going to go into detail about the make-up of this spa for that go to: www.gulfcoastspas.com Purchaser LX-7000 from warehouse dealer 12/22/2006 for $4,000 + $300 delivery & $200 sales tax, Dealer called to deliver 1/4/2007. Dealer agreed to hold until I was ready, delay due to wet yard conditions. Dealer did not cash check until 1/10/2007. Delivery and placement on my patio in back yard was perfect on 1/17/2007. 1/18/2007 I wired the tub. Thought there could have been a pre installed access area or conduit but as explained by the 24/7 service hot line "not everyone wants the same access location" access can be anywhere from bottom, side skirting or thru toe kick that is part of the one piece solid .25mm ASB base. I chose the toe kick. The internal electric box was easy to access and came with a cable/wire box clamp. The box much like my GFCI box has a 4-prong plug for the spa pack. I unplugged it, removed the cover plate and connected my 6 gauge 3 wire + G cable just like wiring a duplex outlet in the house (only with MONSTER wire) replaced the cover and turned on the power. Turned it off quickly and began adding water. Filling thru the filter area (filters not yet installed) I thought might prime the pump. Filling took about 2 hours. Once filled I had to loosen the union on the pump to allow trapped air to escape the line to prime the pump. No water escaped so if any water is detected I didn't cause it and will then look for another source. I had an initial concern that the pump would not shut off, it would run on low and then pressing the control go to high, when pressing control again it would go to low and so on. I later learned via the manual that until the water reaches the thermostat setting the pump and heater would run at low speed and will allow the high speed but NOT turn off. This has to do with the freeze safe mode. Initially the light was working fine but now is not. The control panel shows the "light on" when the switch is activated and off when pushed again. My call to the 24/7 service told me to check the plug-in wiring at the light, which may have lost connection (a job for tomorrow). All water jets are chrome in appearance, not metal but some form of plastic. Cabinet/skirting is EON (brand) Mahogany synthetic with 4 removable panels, each held in place at the top by the tub lip and at the bottom with 2- 2 1/2" (drywall type) screws. Molding strips 2' wide cover where panels meet curved corners and are secured with 3 of the same screws. I would like to see a better way of securing these panels for ease of access only. Insulation: The tub is sprayed as is the inside bottom with High-density foam. This insulation was applied before plumbing, wiring etc was installed making a nicer appearance and I’m sure easier to see leaks or make any repairs. The entire perimeter of the tub has a "bubble wrap" material with double sided foil stapled in overlapping "panels" that are easily removed. Each removable access panel has 3/4" styro foam insulation boards attached to the backside. The cover is 5" tapered with locks and attached "filler" pieces to prevent heat loss at the fold. The water temperature is rising about 5 degrees per hour, with an outside temperature of 34 and dropping. I'm heating to 90 degrees over night and will check before noon. GREG!
TATUM will manufacture for YOU under YOUR label/name. You have to agree to buy a minimum of 1000-1500 spas a year. BUT SERIOUSLY, look at the specs & designs to find the same spa BUT with a different name being sold by a different "manufacturer". Go to Gulf coast spa web site they have retail prices. I bought the LX-7000 for $4,000.00 + $200.00 sales tax + $300.00 delivery on my patio in my back yard. Included cover, chemicals and all the standard stuff on the web site. If you can deal direct with Tatum Ken Sorenson is a VP there 813-840-3151 X 6347 but if not go to Mike Mello at Gulf Coast 727-572-7727 X 5360. BOTH companies are owned by the same person, I've forgotten his name but if you go to the BBB you can get it there. If either of these companies are selling from "the factory" I would say you would have to get a better than I did, after all they don't have to ship it and won't mark-up for dealer profit. PLEASE, let me know HERE or send me a direct email (get it from my ID)
FROM WHAT I HAVE BEEN TOLD (or SOLD) THESE "LX-series" spas are totally new, so I'm going to try to document what ever I can about "MY EXPERIENCE" with this "NEW" series spa. SO............ I took delivery on my LX7000 TODAY. I had the dealer hold it for 2 weeks thinking my yard was too wet and something would go wrong. Two MEN (not boys) and a seamingly a light weight & small trailer, hand wheeled it some 150 feet from my street around to my patio behind my house. The spa was perfectly balanced on the trailer so they didn't fight the weight, just needed to keep on moving. My yard slopes and with the ground being wet (standing water) and 37 degrees (reasonably cold for Baltimore) these guys did an excellent job. Once at my patio they used 4' PVC pipe to easily get it to the exact position. On of the big issues in transporting this spa was to keep it flat (not to turn it on its side like "other" spas are shipped on pallets. Gulf Coast (TATUM Mfg) make a big deal about how ALL their spas are never turned on their side. Final electrical hook-up should be tomorrow and my daily log of repairs/problems/energy consumption will begin. I will monitor tub water temp along with a thermometer to measure the high and low temp just outside the tub and within the skirting (opposite side from the spa pack) to address the concern about insullation. My original plan was NOT to use the AquaClara water system but have since found out that it is manufactured by the same company as ecoONE. There have been recent posts about this enzyme system that show remarkable results with bather load of 3 x A DAY 7 days a week and water changes only every 6 to 9 months! Easy to maintain PH 7.2-8.2, TA 80-120 ppm, and Calcium 150-400 ppm. It comes with a filter to attach to hose for filling to demineralize fill water. Maintenance is: weekly add 1-2 bromine tabs in filter area and monthly adding 8oz "Sustain" & 2 caps full of Enzyme. The natural mineral softners allow a wider range on PH & Calcium. WE SHALL SEE?
Thanks I appreciate the follow up and look forward to how installation of insullation goes. One thing I've been told is not to completly seal the cavity, the motors need air flow for cooling and sealing completly could also cause condensation to form between the tub & skirting. GREG!
