Hello Guys,
I just refilled my hot tub and got the water balance slightly out, due to not compensating for aeration in the PH the first time I turned it on. My numbers are:
TA 120
PH 8.0 (although I'm reducing this as I type, aiming for 7.6 with a target TA of 100, my figures from poolcalculator for perfect balance)
CH 100
FC 10
I shocked the tub to 10ppm FC while the water was heating up, roughly at 33c, 24 hours later I checked to get my CD and the tub had used 6ppm over night and I had roughly somewhere between 0.5 to 0.75ppm CC, so I suspect there was something in the water, so I reshocked the next night and my demand is down to 5ppm FC, with 0 CC, but I'm hoping some of the chlorine was used oxidising, otherwise I think a CD of 5ppm is high after a refill, what do yous guys think? whats a good number for a CD after a refill? I had 3ppm in my head but its more of a guess from reading other threads.
All the chlorine used so far is dichlor to help increase the CYA then ill be using bleach. Would another shock and some MPS help? although if my understanding is right, with 0 CC, then MPS isn't really required? is that true?
Another question If I may and I know this one is very much dependent on each individual, but roughly, after using the hot tub, how much FC per person do you aim for? I know this is based on how much bacteria is introduced, more = more FC, and you just can't tell, so I'm really just looking to get a rough minimum number in my head, maybe a per person per hour basis, so far I've just been increasing the FC to roughly 10ppm after its been used and rechecking to ensure its not all being used too quickly!
