Pool Owner
19 -
Contact Methods
http://poolforum.blogspot.com/
Gender
Orange County, CA, USA
Gender
Pool Owner's Achievements
Where Can I Buy Clorox Bleach In Uk?
Pool Owner replied to jacko64's topic in Hot Tub Water Chemistry
You may want to contact Clorox directly (http://www.thecloroxcompany.com). On their website they list the UK as “Clorox headquarters or division office” and “Clorox manufacturing facilities (either Clorox owned or joint venture)” Therefore, I would expect it to be readily available. Good luck. -
Since you have a spa, have you tried draining and refilling the spa, and are still having the problem? If not, I would try that first to see if it goes away. It could be that you are allergic to something in the chemicals and/or in the water that is not being killed. It is my understanding that you still need to use a little chlorine along with the bromine to reactivate it and kill all of the bugs, so you may want to double check the instructions for using bromine. For the future, you may want to invest about $30 into getting a good reference pool book. If you have not yet done so, check your local library for books on the subject of pool maintenance/construction to see if there is one you like. I have a short review of a few books on my blog (noted below). While it is very large, I think you will find “The Ultimate Pool Maintenance Manual” a good choice. Since it is almost 700 pages, you need to use it like these pool bulletin boards, search for the information you need and only read the part that covers your problem. The same author has a book intended just for Spa owners which I have not read.
While I am an experienced DIY, I hired a pool builder because it was too much of an investment to get wrong. I utilized my DIY skills to keep on top of the project, asking questions and providing direction to get what I thought I wanted (I did learn a few things that I will eventually share on my blog). I have some information that may be useful on my blog. There is one link for a DIY gunnite/plaster pool website. For the future, you may want to invest about $30 into getting a good reference pool book. If you have not yet done so, check your local library for books on the subject of pool maintenance/construction to see if there is one you like. I have a short review of a few books on my blog (noted below). While it is very large, I think you will find “The Ultimate Pool Maintenance Manual” a good choice. Since it is almost 700 pages, you need to use it like these pool bulletin boards, search for the information you need and only read the part that covers your problem. I’m in the process of reading a few other books on pool construction; however, none of them are complete enough for DIY.
Walter, I think the basics include utility connections [e.g.; water; power (electricity); fuel (natural gas, propane, and fuel oil); sewer; or storm drainage) as needed for your intended pool equipment and/or building department requirements. Other possibilities include, conduit for pool equipment automation and/or audio speakers, underground supply and return pipes for solar heating, etc. If you have not yet done so, you will want to determine a likely location for your pool and equipment platform, as well as, planning/building department setbacks and requirements. My rule of thumb it that it is usually MUCH less expensive to provide needed and extra underground pipes/conduit installed early that may be unused, than the cost of installing something you needed later after your landscaping is completed. Do not forget that construction access will be needed for installing a pool, which can significantly damage any existing hardscape and landscape in the path. For the future, you may want to invest about $30 into getting a good reference pool book. If you have not yet done so, check your local library for books on the subject of pool maintenance/construction to see if there is one you like. I have a short review of a few books on my blog (noted below). While it is very large, I think you will find “The Ultimate Pool Maintenance Manual” a good choice. Since it is almost 700 pages, you need to use it like these pool bulletin boards, search for the information you need and only read the part that covers your problem. Also, I have links on my blog to a few pool construction sites that may be helpful. Good luck!
What Is The Ideal Concrete Slab For A Tub?
Pool Owner replied to pnwtub's topic in Portable Hot Tubs & Spas
pnwtub, sorry for the delay in getting back to you. Fiber mesh has been used in concrete for at least two decades. It does not provide any structural strength to the concrete; therefore, I would not recommend it is you have an expansive soil concern. The fiber mesh is similar to 1- to 2- inch chopped pieces of “fiberglass” added and mixed into the wet concrete. The fibers help to hold the concrete together across their length, so it has proven to be an effective method for reducing “micro cracks” in concrete. Micro cracks can be penetrated by water and can increase the likelihood of concrete spalling during the freeze-thaw cycles in colder climates. As to the size of the slab, generally this is personal preference assuming it is properly constructed. What you have described should work. I do not think there is any one absolute right or wrong method for installing an above ground spa’s support structure. My recommendation is to pick a contractor you feel comfortable with and ask to see some examples of their work in a similar situation (e.g., soils, use, etc.). Also, unless you are comfortable with construction terms and methods, I would recommend that the contractor pull building permits to ensure the final installation meets all safety requirements (e.g., equipment bonding, etc.). Luckily the prefabricated above ground spas are sold with most of the safety concerns address in the manufacturing process and/or installation instructions. Good luck. -
Greg (GKL), it sounds like you have a good plan (get use of your spa sooner than later). If your existing pavers patio has been around for a few years and is in good shape, utilizing similar base construction should be adequate for a concrete slab (even 4-inch). Roger confirmed that concrete can be placed during cold weather by knowledgeable contractor/finisher that is willing to do the job right. -
Generally I would expect a 4-inch slab to be adequate, especially with the base you described. And if there was an existing slab I would say “go for it.” However, if your “heavy clay soil” is expansive, I would consider increasing the slab thickness to 6-inch and using at least #3 (maybe #4) rebar at 12 inches on center both ways (at least the section under your spa). It all comes down to construction cost vs. repair/reconstruction cost. It is not that hard to reconstruct a typical slab on grade but if your spa slab cracks for tilts significantly, it will require removing your spa during reconstruction. Check out the cost for a few more inches and better reinforcing steel under the spa. I’m from the “old school”…”when in doubt – make it stout!” If it is only a little more money up front, it is well worth it in the long run. -
Good question. Concrete can be placed in cold weather but it is more difficult. Doing a Google search for “cold weather concrete” will provide a number of good resources. Basically if your concrete contractor/finisher is knowledgeable about the process of working in cold weather and is prepared to provide the supplies/manpower to properly cure the concrete, it should not be a problem. If you can wait and you expect a warm spell, it is safer to place concrete when the minimum air temperature remains above freezing (say 35 degrees F). http://www.askthebuilder.com/104_Cold_Weat...tallation.shtml http://www.deeconcrete.com/coldweatherconcrete.html http://www.na.graceconstruction.com/custom...ads/TB_0106.pdf The above websites may be helpful If you go ahead, the procedure shown here should work for you (http://www.decorative-concrete.net/feature_11-04-02.php) -
6 Month Ph Stabilization Product?
Pool Owner replied to Pool Owner's topic in Swimming Pool Water Chemistry
chem geek, thanks for the thoughtful reply. I will check with the store manager after the first of the year but I may not be able to get any more information until after their March manager's meeting when he expected to get the okay to sell the "product" durning the 2007 swim season. However, being in Southern California where we do not close pools for the winter, I expect he will start selling the product as soon as it is in the store. I will let you know when I get any more information. -
Is there really a (new) product on the market that will keep the pH in the 7.4 to 7.6 range for about 6 months? Do the water experts and/or chemists in the group have any information? I searched the forum and could not find anything, but if it is there please point me in the right direction. Yesterday I was in my local national retailer. In talking with the manager about my need to frequently lower the pH in my less than a year old plaster, 30,000-gallon pool with a salt/chlorine generator. He said that pools with salt/chlorine generators are always fighting high pH (I assume vs. those using acetic dichlor or trichlor products for sanitation). And, there is a new product they will likely start carrying early next spring that will maintain the pH in the optimal range for about six months. It is in testing now and showing good results. He expects the product to retail for about $60, which averages out to about $10 per month. If it really works, the new product cost would not be much of an increase for me and probably worth the extra money if it keeps the pH down. What’s the word?
To help removing scale before draining your spa, try ScaleTec Plus. You should double check that it is okay for plastic/fiberglass shells. It is from McGrayel Corporation, Easy Care Products Division, which is located in Fresno, CA, USA. Their website is www(dot)mcgrayel(dot)com; however, it has had problems every time I’ve checked. I have found this product at a few local pool supply retailers and just today my local Leslie’s. Reportedly it is real good at removing scale with natural chemicals, which are less likely to create other water chemistry problems. Please reply to your post with your solution (especially if you used this product and like/dislike it).
Sanitizer and algaecides might harm your grass. Since you are going to be changing the water anyway, let your chemicals get as close to neutral as possible before discharging your spa water onto plants. If your soil has adequate drainage and the water does not puddle, it is doubtful that you will over water the grass since the amount of water in your spa is likely to be less than 1-inch of rain would provide to your yard (stop automatic sprinklers if needed). Since you have a septic system, I assume you have a relatively large area for your drain field. 100 gallons of spa water at an average water level of 1-inch will spread out over about 160 square feet of grass (heavy day of rain in my area of the country). Therefore; if you have a 1,000-gallon spa, you would want at least 1,600 square feet of grass to absorb the water. If you are concerned, drain your spa in portions over a couple of days with about 8 hours between each draining session. You can increase or decrease as needed for your specific soil conditions.
Temecula, California - Would Appreciate Feedback
Pool Owner replied to topnurse's topic in All Swimming Pools Types
topnurse, you are probably done by now, but if not, here are my thoughts…It sounds like you are doing all of your homework. There is a lot of good information on California’s Contractor State License Board website (http://www.cslb.ca.gov/), including “Before You Dive Into Swimming Pool Construction...” publication. After talking to a couple of larger pool contractors, I ended up using a small company (Titan Pool in Anaheim) because of strong personal recommendations. If you have not yet done so, check your local library for books on the subject of building a pool. I have a short review of two books on my blog (noted below) and I have not yet gotten around to reviewing “The Swimming Pool” which is another book I like that is geared towards new pool construction. -
Pool Plumbing, Drain Tile And Retaining Wall Question
Pool Owner replied to dlsdo's topic in All Swimming Pools Types
For my two cents, your new pool is a significant investment and it is not easy to change the plumbing after the fact, so get your pool builders (or the one you like best) to explain the differences and why they recommend the choice they made. Like the other answers here, I would prefer to have individual lines because it provides more choices down the road. Many times the main drain line is connected through a skimmer to prevent running the pump dry if the water level gets too low. A 15 foot high retaining wall is a significant structural element that should be designed by a structural engineer based upon an on-site soils evaluation by a geotechnical engineer. Your investment in your pool is too great not to use the right professionals for the job. It might cost you more up front in design fees but do you really want something almost two stories in height moving any more than anticipated (all cantilevered retaining walls do move some). Slope stability and drainage will be critical for your retaining wall, so spend a little more money during construction to get the structural engineer (and maybe geotechnical engineer) out to review the site during construction. If you have not yet done so, check your local library for books on the subject of building a pool. I have a short review of two books on my blog (noted below) and I have not yet gotten around to reviewing “The Swimming Pool” which is another book I like that is geared towards new pool construction.
