timboxx
timboxx's Achievements
  1. Okay, thanks for the information. I'll let you know what the outcome is. Timbo OK, here is what happened. Previously my Jandy 1400 salt system was getting 120 & 121 codes, had lots of buildup in the cell, and I was getting green looking algae on the pool walls. I am not a pool guy and had not been trained on the system even when it was installed several years ago. The pool company said to clean the cell with the 4-1 (water/acid) solution and if that didn’t work, I should buy a new system. I proceeded to submerge the cell in a bucket and let sit for 20 to 25 minutes then blow out with a hose. I could see pieces of the buildup coming out but nothing changed as far as performance. I was getting the CELL ON light and assumed it was trying to produce chlorine, just not enough to make a difference in the pool. I was almost to the point of buying a new cell and made a final attempt to clean the cell. This time I did not let the cell sit in the solution, instead, I prepared 3 ½ to 1 (water acid) and poured the solution through it, (gloves and glasses on) over and over again. This action seemed to remove more of the buildup, then blew it out with a water hose. I did this two times on consecutive days. ALAS, I have a sparkling blue pool, no algae and it’s been two weeks now. I’m still monitoring it closely but so far so good. I now know I need to clean the cell every few months to keep the buildup away. Thanks for your help Pool Clown. Timbo
  2. Okay, thanks for the information. I'll let you know what the outcome is. Timbo
  3. OK on that, but, I think my next question is, if the (cell on) light is on, is it producing chlorine? Or trying to produce chlorine? Maybe just less than it should and it’s still a dirty cell, or could it be giving me a false reading. My hope is, if I keep cleaning it every day, maybe it’ll come around. Are the insides of the cell really that intricate and even a little buildup could be giving me trouble. About to pull what little hair I have left out… Timbo
  4. Help Me Pool Clown, I have a Jandy 1400 salt system. I am getting 120 & 121 codes. I cleaned the cell with the 4-1 water-acid wash and blew it out with a water hose but still getting the code. I am getting algea and no chlorine. The amber service light is on along with alternating flow, cell reversing and cell on. The system is 4 years old and has had no problems till about 2 months ago. I am so frustrated. The pool store said I probably need to buy a whole new system. ($$$) Should I buy a new cell or could it be something else? Also, it's a two port cell, If I need a new cell, should I try to find an old 2-port or upgrade to the three? Thanks for your anticipated help. Timbo
