We recently acquired a 1998 (I think) Hot Springs Portable Spa Classic (Model F) with a home that we purchased. We were told that it worked. With winter over we cleaned it up and tried it out. We filled it up with water and tried the jets out and though they cut out a few times, after a few tries they stayed on for 10-15 minutes before we turned them off and set the water temp for 100 degrees and went inside. I went out to check on it about an hour later or so and noticed that the hot tub now had no power to it. I unplugged the cord several times and plugged it back in again but can not getting any power on the hot tub. The outlet has power as I tested some other items, but no matter what I try I can not get anything on the hot tub to power up.
I am not sure what the problem is and the owner's manual is not very helpful. Like I said everything seemed to be working just fine - except the heater which I did not have enough time to tell if it was working.
Has anybody had something similar happen to them. Or does anyone have any suggestions as to why this might have happened? Let me know if you need any more information. Thanks in advance for your responses.
