I am looking for a bromine floater for a small tub. I have tried three and all allow too much bromine into the water. One floater uses vertical lines and and a sliding tab to cover them, one uses horizontal openings and you screw the thing in and out and the third is a small floater with zig zag openings which you twist back and forth. If any hole is open any amount (I mean even a slight crack) the bromine goes to 10 ppm in two days.
I have went to the bromine two step method for control and that works.
Is there a plastic patch or compound which will last in spa water so I could fill all the holes and drill small openings to give me the control needed.
This is a 145 gallon spa.
