Hi looking for new spa. Had a Jaccuzi Z140 from Home Depot for 10 years. Moved and now considering this Costco Cal MOC 850L for 5k. Your thoughts are appreciated.
The Z140 was my first spa we enjoyed it. Wanted to be sure whatever I buy that parts are available.
Also liked the Cal Spa for its 425 USG quite larger then Evolution Spa's 355 USG. Wanted to spend up to 5k.
< Previous Product | Next Product >
OC Hot Tubs 50-Jet, 6-Person Lounger Spa by Cal Spas
Majestic Series – MOC-850L
Specifications:
Seating: 6 person
Dimensions: 84” x 93” x 39.5”
High Performance Pump: 2 x 6.0 BHP
Jet Count: 50 stainless steel
28 micro flow directional jets
11 power storm roto jets
8 power storm twin roto jets
3 power storm roto jets
Weight Dry / Filled: 1096 lbs. / 4,648 lbs.
Water Capacity: 425 USG
Pump Voltage: 240V (Electrical connections must be made by qualified and licensed personnel. Improper installations present hazards, which can result in personal injury or property damage. Please contact a licensed residential electrician for these services)
Heavy duty 5.5 KW heater
Filter: 75 sq. ft. floating pop up
Water Treatment: 102C Ozonator installed
2” Plumbing
High density full foam insulation
Maintenance Free Synthetic Cabinet Panels: Mahogany
Shell Colors: Snow white or silver gray
Features:
Lighting: 12V spa light
Water purification system
Low profile drain
Wall drain
Cabinet accessible drain valve
Gate valves
Equipment: "VSP-501SZ with digital top side"
Pressure treated cabinet frame
Standard bottom tray
3 comfort pillows
Bottom cover lift
Standard Cover: Standard rust 5” taper to 3”
Please click here to view shell, cabinet and cover color options.
Warranty:
5 Years - Structural
2 Years - Finish
2 Years - Parts
1 Year - Labor
Ordering & Delivery:
