I'm having a problem with my 8 year old Sta-Rite pool heater.
All LED lights started flashing, then none of the buttons on the pad would work. I assumed the control board was faulty and replaced it. My old board part # was 420010096S. The supply company said that part number was replaced with a new board, #420020007S and that the new 6 pin board would work with my 9 pin connector. The new board looks completely different. The cables fit from the membrane pad fit, but the board has a couple more connectors than I have cables. Bottom line, the new board didn't fix my problem.
When I power up the heater, the new board lights up flashes a couple diagnostic codes then goes dark. None of the buttons work. This is the same problem I had with the old board.
It seems that either the new board in not compatible or the cable connector from the membrane cover to the board is bad.
Pool Clown you helped me before with this heater, any suggestions?
