It is only slightly murky and there doesn't appear to be any odor. I did fill it up with city tap water and I am not aware of Aquafiness....
I have emailed my local retailer, but I guess a phone-call is more direct and will likely get a faster response. I have had the water professionally tested, and at the time, I only
had to adjust the Calcium Hardness and slightly lower the bromine by reducing the flow through the Brominator, but it seems like it has no affect. If I reduce it to low, the Bromine reads zero, if I increase the flow, it reads to high, or at least, that is now the strips are read. I used to have a digital read-out, which works, but I ran out of those test-strips, so the liquid test may be more what I am looking for, if it provides a digital read-out. I am hoping the dealer can come out as part of their warranty coverage to see what is happening.....
The filtration cycle is set to FD02 and FF04, which is the most frequent use of the filtration cycle.
Thoughts? I remember using a liquid indicator test kit when I had a pool in Phoenix, so I don't think it would that difficult. I would likely prefer that over test-strips as some test-strips can be faulty and provide false-readings....
Paul
