I've had my spa for about 6 months now and have just done my second refill. After much reading here I am planning on implementing the dichlor/bleach method, and though I may have some questions regarding water balance later, my concern now is the sanitation part of the equation.
After my refill, I got my water close to balanced with a CSI from the pool calculator of -0.19. I will continue to work toward 0 but I thought that this was close enough for now and shocked with dichlor. My aim was 10 ppm FC, but I wound up at 12 ppm. After sitting unused for ~24 hours I retested and my FC was 4 ppm. This means my freshly filled, 6 month old spa is using 66% of the free chloride I introduced last night. This seems troublesome to me and I wonder what might be causing this. My Combined Chlorine was only 0.5, so that seems ok. Any thoughts on what might be happening or follow up ideas would be appreciated.
Secondarily, when I test FC with the Taylor kit I reached the clear color endpoint, but then when it sat for a couple of minutes a pinkish hue developed and I added another drop, and then again, adding another 1ppm. Is this right or should I have ended at the first stop?
