ain question ! Was this panel part of the hot springs hot tub sent assembled inside the hot tub or was this an accessory panel that came with the hot tub or bought as an extra. If it came as an integral part of the hot tub mounted within the hot tub then it would be a violation of installation instructions as required in article 110.3.B. 000-965 braindumps If this was an accessory panel then you may install a 50 amp branch circuit to the hot tub to serve the inline heater and a 20 amp 120 volt branch circiut to serve the motor as two separate branch circuits. Remember this hot tub must have a form of disconnect in sight of that hot tub. A 20 amp single pole switch would do the trick but often times a 4 circuit weather proof panel installed insight of and not more than 50 feet but at least 5 feet from the hot tub may be used installing a 50 amp GFI double pole breaker and two 6 awg copper hots and a neutral and a 10 awg copper grounding wire feeding the 4 circuit subpanel insight of the hot tub then installing the two circuits one for the in line heater and one for the motor. JN0-140 braindumps Hope this gives you come ideas.
