Hello, we are taking the plunge (pun intentended) and building an inground pool. The specifics are: free-form concrete walls with vinyl liner, 23,000 gallon capacity, Jandy 1.5HP e-Pump, Jandy DEV48 DE filter, Jandy AE2500 heat pump, Jandy Aqualink Power Center with 14-blade cell kit and Jandy PDA-P8 wireless control system. I was going to install a Polaris Halycon booster pump for a Polaris 280 cleaner but was told by a tech support person from Zodiac Pool Products that I do not need a separate pump if I have a variable speed pump. The tech support person told me to install a 3-port valve with a Jandy valve actuator to divert water to the dedicated return line for the Polaris cleaner. He said that I could adjust the pump speed until the correct pressure and flow for the cleaner was obtained.
Now for my questions:
Has anyone done this?
How well does it work?
Where would I tie in the 3-port valve for the dedicated return line?
Thanks in advance for your help.
