We've had five different fiberglass pools over the past 26 years and have never had a problem like this. Our chemicals were perfect during the past very hot summer in SC, however as the weather cooled in September, the pool turned a light green color. I cleaned the cartridge filter and it was coated with a thick, slimy, grainy white substance. About 2 weeks later, I discovered that same white slime-like substance covering the entire pool surface (under the water line). When you rub your hand over the surface, you get a chalky, slimy substance that is quite thick and doesn't dissolve off your hand in the water. You have to rub hard to get it off your hand.
I went to the local pool store for water analysis. Here's what they gave me:
FC +5
TC +5
PH 7.4
TA 110
AA 80
CYA +100
CH 70
salt 4,000
phos 2,500
They wanted to sell me a bunch of products to lower phosphates and deal with the green color, which they said was absolutely algae, and told me to start by draining half my pool to bring CYA down to 50. But my concern was with the slimy white substance coming off my pool, which they said they had never heard of. Because I've had bad experiences with folks who supposedly were trained in pool chemistry, I told them I wanted to research the slime problem before adding any chemicals. In checking various sites, it seems my slime problem is due to low CH, but that my CYA level was in fact too high. So I drained about 5", filled and went back to the pool store to purchase a calcium increaser and have the water tested again. This time I got:
FC +5
TC +5
PH 7.6
TA 120
AA x
CYA 90
CH 60
salt 4,000
phos 1,000
Again, they wanted to sell me a bunch of products to "aggressively" attack the algae problem and lower phosphates. I told the clerk that I believed reducing the CYA would allow the chlorine to be effective and I wanted to do that before purchasing any products. She said, "In my professional opinion, that isn't true. Reducing CYA won't help the algae problem." But this is the same clerk who had no idea why the pool was scaling and didn't understand the chemistry of phosphates and why the product she wanted to sell me to reduce phosphates would work.
I have NEVER put a stabilizer in this pool. I have a 17,000 gallon fiberglass, with salt water generator and cartridge filter. I keep the filter clean, and balance PH, TC and TA but don't check anything else other than the salt level (which is provided by the SWG system). We had a lot of rain this summer, so had to drain off several inches of water 4 or 5 times. As a result of draining water, we had to add salt to the pool to keep our levels correct. I suspect our problems were caused when my husband purchased salt pellets (perhaps meant for a water softener) which must have had inert ingredients that caused the low calcium and high phosphate levels. I have in the past used chlorine tabs in the winter (when I shut off the SWG) so that might have caused some of the phosphate problem, but I've always used tabs in the winter, so don't think that alone would account for such a high phosphate level.
My question is this. The local pool store told me to put 10 pounds of calcium increaser in, then a bunch of Phos Free and other products to reduce phosphates, then about $100 worth of algae treatment. Do you think the calcium is the cause of the white slime, and do you think I really need to reduce the phosphates now, considering they dropped 1500ppb by simply draining off 5" of water? Or should I drain more water to reduce CYA and phosphates even further?
I purchased the calcium increaser from the pool store, but nothing else.
