Paul,
Thank you for your very indepth response. I will take your advise and give it a try. All the amp and volt reading appear within tolerance. I will try once again to clean it and see if that makes a difference.
Welcome to the forum and again, thanks for the response.
R/Don
Okay, thanks.
I'm guessing there is no way to recalibrate this device. Searching the internet, calling technical support, and posting to this list have not provided a means to recalibrate the device.
Again, thanks.
Thank you all for your insight and taking the time to post.
I'm actually looking for an unpublished sequence of buttons that can be pushed to reset the AQL-PS-4 Aqua Logic salt reading. I have tested the water on several occasions at different pools stores and the AQL-PS-4 is consistently reading 1000 ppm lower than the pool stores are showing.
Thanks in advance.
The main reading that you first see is a average. Pressing the black button until the negative number show, that is what the cell is reading right now.
with the pump running take the switch from auto to off back to auto. This reread the salt level by the cell in the negative number setting.
Switch from auto to super chlorinate to auto will put the number on the main display(number with no - sign and erease all the average readings
The test strips for testing salt need to be timed properly. The longer you wait the high the salt reading will be even though it is not. If you are between 2700-3600 you are ok
Thank you for the quick response. Does this apply to the AQL-PS-4?
I will have to check on that one
Thank you all for the suggestions and taking the time to post.
I'm actually looking for an unpublished sequence of buttons than can be pushed on the AQL-PS-4 to reset / recalibrate the salt reading. I have had the water tested several times at different pools stores. The AQL-PS-4 Aqua Logic is consistently reading about 1000 ppm lower than what the pool stores are showing. If anyone can post the sequence of buttons that when followed resets the salt reading it would be greatly appreciated.
Over the past 6 weeks my AQL-PS-4 is reading approximately 1000 lower than the what the salt level shows when testing at several pools stores. Is there a way to recalibarate this to provide for an accurate reading? I get the same consistent low reading on both a positive and negative polarity.
Thanks.
