TomC
49 -
TomC's Achievements
Hi, I am assuming that this is not a rhetorical question. Actually, in the back of my mind I have to think that Arctic Spa put the pump mounts in for a reason. Plus, we have received some very shoddy work from the Arctic Spa tech's in the past and I felt that a forum such as this would yield more reliable results/opinions. Thanks
Hi, One of our pumps had to be serviced and now it is time to put it back in. When I had the pump out I spoke to an Arctic Spa technician and he said that they don't use the pump mounts - they just rely on the hose fittings to keep it in place. Since it is a hassle to use the pump mounts it is my preference avoid using them if possible. If necessary though, I will clamp the pump down with the mount. Any one have input on this? Any input on this would be greatly appreciated. Thanks...Tom
Hi All, We have an Arctic Spa and while cleaning it yesterday I heard water dripping into the cavity. I opened up one of the service panels and noticed that one of the top side valves was not connected to anything (no tubes, nothing), and any water that splashed over this valve (from rain or water sloshed from tub use) simply flowed directly into the cavity and pooled. Is this not weird? Firstly, we always thought that valve must do something (although we never could figure out what it was doing - which turns out to be nothing). Secondly, water dripping into the cavity and wearing down the insulation foam does not seem like a good design. I called our spa maintenance company and they said that is normal and that it is needed for air flow. I feel bad, I was sort of snippy to them in my email describing the problem and now he says it is the way the tubs are designed. It is probably time we moved away from those maintenance folks anyway but maybe I was too harsh (it just seems crazy that a "valve to nowhere" that causes water to flow into the cabinet is normal. Thanks
Hi, I am very interested in your outcome. I have been fighting the exact same thing that you describe, and I have tried everything. I have concluded that it is not bacterial (for some reason most people assume it is bacterial). My reasons for thinking it is not bacterial is because I had a very similar reaction to sea water. Assuming that my reaction is chemical related, I systematically tried reducing the chemicals we put in the tub. We have a salt system and we have tried; reducing the amount of salt used, turning down the generator to the minimum setting, minimum calcium hardness, and minimum buffer. None of these changes made a difference, still got the rash. Then I focused on ph, raised it into the upper ranges but still go the rash so we lowered the ph and still got the rash. We have tried chlorine, bromine, Spa Marvel, and Hydrogen Peroxide as sanitizers - nothing relieved the rash except limiting my exposure to the tub. So, it is all very frustrating, to say the least. Unless someone has other suggestions, I am left to conclude that it is a sensitivity to warm/hot water. If anyone has fought through this sort of thing then I would love to hear from you. Tom
Hi, Consider this a cautionary tale. We have an Arctic Spa tub with a salt generator. Upon reflection, we would never go with another salt system. Our first generator died after a couple of months (according to the sales people, those generators were just plain bad), so we got another one. The "new" one died after a year or so, and again we bought another model. Well, this one just died and the maintenance guys conceded that they have a life span of about 2 years. The new unit, installed, will be about $300. You can buy a lot of chlorine for $150/year (assuming they cost $300 and last two years). In retrospect, we bought into the whole concept of it being better, less chlorine needed, new and fancy - all that jazz. Our recommendation is to save your money and just go with the tried and true methods of sanitizing with either bromine or chlorine. The salt system is just a chlorine system anyway. Is our experience typical? Tom
Hi, Although I am no expert on hot tubs, unfortunately I have first hand expertise on rashes and itches that seem to be related to hot tubs. After about 2 years of using the tub I started to develop dry itchy patches of skin. At first I thought it was related to the pH of the tub but we corrected the pH and the itch persisted. Then I thought it was the sanitizer. We were using a salt system so we shut that down and switched to bromine - didn't help. Then we moved from bromine to hydrogen peroxide - didn't help. From there we moved to the BBB (bleach, baking soda, borax) method. This BBB didn't help the itch but it is way cheaper ;o) Long and short, I am pretty much convinced that my skin just reacts to long exposure to hot water. I did go to a dermatologist and she prescrided an over the counter cream called Glaxel Base that does seem to help, plus she put me on an antihistemine (sp) to get the flare up under control. The meds did help but not in the long term. All I can really say is that you may be reacting to your sanitizer, but then again it could simply be the hot water is drying up your skin. I shold also add that I never had foliculitus - although I thought that is what is was initially. Good Luck...Tom
Hi Everyone, Sorry for not posting our numbers - we have been away.Anyhow, we added some clarifier, changed the filter, and boom, looks like a million bucks again. We have been using the bleach method of late and it is working really well. Totally undecided if we will return to Hydrogen peroxide, time will tell. Thanks Again...Tom
Hi Everyone, Our hot tub water went a bit off last month and we managed to get it clarified with no foam but adding bleach. Recently though, the water is a bit yellowish(nothing really noticeable), no odor, and no foam. In short, the water is clear and seems fine except for the very faint yellow tinge. Anyone have any ideas on what may be causing it? We should add that we are not using any sanitizer at the moment. We were using hydrogen peroxide but while away on holidays friends used the tub and the balance went off. So, since it is summer, we have just trying to keep the water from fouling completely by adding bleach. In the fall we will get serious about it again but in the meantime, is there any explaining why bleach only makes the water a tad yellowish? Thanks...Tom
Hi All, We started with salt, then moved to chlorine, then to bromine, and now finally to Hydrogen Peroxide. This jumping about has been spurred on by an itch that I developed from our hot tub. As it turns out, I am now thinking that it may not even be tub related - but that is another story. The jury is out on Hydrogen Peroxide but we do have to admit that it is non-odour, it appears less toxic, and we were just getting overwhelemed with other santizing regimes - but again I digress. We went out of town a few weeks ago and upon our return we noticed that the water was going a bit cloudy, with some foam. We dumped in a bunch of bleach, cleaned off the filter, and bingo, the water is back crystal clear. In the past, we used to just dump the water when it got foamy and cloudy. Seeing how easily we revived this water (mind you the water was not that old anyway), we are wondering if we can extend our fill-ups every time the water looks less than pristine. Can get just dump in bleach and freshen up the filters if the water is looking dodgy, if after 3-4 months for example? Does anyone have thoughts on this? Thanks...Tom PS...sorry, we initially added this post to the "above ground pool" forum. Noticed it shouldn't be there so we added it to this forum as well. Moderators, feel free to kill the thread from that forum...thanks
Ooops, it was Peteyboy who responded in regards to the filter cleaning, not Cramp. It seems like you both have a handle on it, any advice from either of you is appreciated ;o) Thanks...Tom
Hey Cramp, Do you happen to have a name for the solution you clean the filter with? Plus, do you just soak it in a bucket? The reason that I ask is because I have received a recommendation to soak the filters in a Hydrogen Peroxide/water bath. HP tends to be expensive though, and since it is expensive, I was thinking I might need a special vessel to house the solution (which I can buy). The HP solution so far has been great. The last step is to figure out how to clean the filters so any light you can shed on it would be greatly apprecaited. Thanks in Advance...Tom
Cramp, I gather you just leave it in the soaking soltuion until it is time to pop it back into the tub (or do you soak it for a few hours, remove it, and let it sit until you are ready to swith it)? Do you do the TPS step? If so, where can I find this TPS stuff? Oh yeah, I gather that you have to add new cleaning solution each time you clean a filter, or can you just keep using the same solution over and over? Thanks Again...Tom
Hi, In an attempt to ease my eczema we have just switched over to Hydrogen Peroxide. We have diligently been reading the posts on here about using Hydrogen Peroxide but we are a bit confused on the filter maintenance impacts. For example, we noticed something about TPS to clean the filters. What is TPS? Plus, is it written anywhere on how or how often to clean the filters. Is there anything else we should be on gaurd for when using HP? Thanks in Advance...Tom
Hey Cramp, Thanks for the reply. Changing/cleaning the filter every week may be an issue (we are not the most diligent on such things). Is the hydgrogen peroxide route expensive? In approximate terms, what would a three month supply cost? I gather start up, after a fill, is the expensive part. Do you use 29% or 35%? Is a product from one of the spa companies (such as peroxisan), or simply hydrogen peroxide? I was reading some other posts you have and you initially had "floaties", did the peroxide sort those out as well? Although I have not looked indepth yet, I am starting to think that HP may be hard to find here in Ottawa. Thanks Again...Tom
