cpumodem
cpumodem's Achievements
Junior Member
  1. Flyguyscott I too have an Arctic Glacier with Onzen. I have had the tub since July 2008 and had the Onzen replaced in March 2009. I do not use the salt that produces bromine as the salt that I user produces chlorione. First off for all the problems that you are having contact your dealer for support. On the Aqua Finess my opinion is that the dealer is trying to make more money from you. Ditch the Aqua Finess... Also I would switch to a Taylor Tesk kit. You will find that the test strips are not as accurate. The only chemicals that I use are: The salt only used when filling up the tub Chlorine to be used only after heavy tub use to establish a chlorine reserve. You will notice that heavey use there will be no sanatizer left. Arctic Refresh Ph up PH Down You salt level seems high. When I fill my tub I only use 1/2 of a new bucket of salt or 5 lbs. How much salt did you put in the tub upon fill up? When I do a water change every 3 months here is what I do. 1. Before I power down the tub I change the CP setting to 0. 2. Turn power off and drain tub 3. Clean tub and before I refill it I put on the pre-filler on the hose and fill tub. 4. Turn power on, run on slow speed for 3 to 5 minutes and then run on high speed for a minute or 2 to get the air out of the lines. 5. Get the 5 pounds of salt ready to put into tub and wait until the water temperature is 85 degrees then open up the air and run both pumps on high. 6. Slowly pour the salt into the tub. Should take you about 10 to 15 minutes. 7. When the pumps turn off after 20 minutes running the first pump should be running only on low speed as the tub will be heating up. 9. Go into the low level programming and set the CP from 0 to 3. (you have the salt in the tub now so it time to turn the Onzen on) By morning I have 3 parts of Chlorine and clear water so that I could use the tub. But again you paid lots on money for this tub contact your dealer for help.
  2. Changed my water this Monday the 28. Outside temperature at the start was 19 degrees and when I finished it was 22 degrees. I have 2 hoses that I use to drain the tub. A 25 foot hose that connects to the tube drain and the other one is also about 25 feet cut from an old hose that I put in the middle of the tub and start the syphon from the other end manually. Using 2 hoses the tub will empty in an hour and 20 minutes. Started @ 10 AM and was finished with the tub filled by 12:30PM
  3. James, Thanks for the update. I posted the story becuase it contained economic information about the global recession and also how your company is doing during these tough economic times. I trust reporters as far as I can throw them. What I like and I'm sure other readers will also is the interest that you and your company take in resolving issues and complaints. Last year I wanted to replace my 9 yeard old Apollo Hot Tub and after researching on this forum and seeing at that time Tom responding to questions and complaints I decided on an Arctic Glacier Signature with Onzen. I got my Arctic Glacier in late July 08 and the only problem that I had was that the Onzen generator quit woking in Feburary 09. After getting the Onzen replaced it has continued to work. The only request I ask of you and your company is that the Onzen manual nned to be re-written as several people including myself have complained about the manual.
  4. Orders for Mr. Keirstead's Arctic Spas tubs are up after an “extremely weak” first quarter. However, Mr. Keirstead isn't confident the resurgent demand will last. “Some fundamentals just aren't there,” said Mr. Keirstead, co-owner of Blue Falls Manufacturing Ltd. “I feel we aren't looking at a V, more of a W,” he added, referring to the trajectory the rebound could take. “We could see some problems this winter.” Blue Falls Manufacturing has fired 120 people and Mr. Keirstead says he has no plans to bring them back. The company is on pace to sell about 7,000 spas this year, down from 10,000 before the recession. Instead of building inventory, Mr. Keirstead is filling orders as they come. “It's coming, but it's not coming that well,” Mr. Keirstead said. “I don't know how soon we'll truly get back to previous volumes.” The story can be found at: News Story
  5. I have an Arctic Glacier and you are correct after a high usage you will need to supplement it with adding normal chlorine ( you don't want the bugs to grow). One of my gripes is that no where in the Onzen manual it states that after heavy usage you might have to supplement chlorine.
  6. If you are not getting the mist it would probably mean that the electrodes are not working. My Arctic tub did the same this last winter. Since it was a cold winter I just put the regula chlorine in the tub and waited until spring to get the tub fixed.
  7. Welcome to owning an Arctic Spa. I also have an Arctic Glacier with Onzen that is now 14 months old. The only problem that I had is that it quit making chlorine and the Onzen Electrodes needed to be replaced. Just yesterday it was time to replace the water with new. It was also the first time that I cleaned the jets. Was surprised after 14 months of use the jets looked like new and very little work was needed to clean them. Wife an I use the tub about 3 times a week and I have the Onzen generator set to run for 8 hours a day. If I go on vacation for a week I cut the time in half and only run the Onzen system 4 hours a day until I get back. If you have any questions fee free to ask. Chuck
  8. How are you cleaning your jets durning a water change on an Arctic tub with onzen?
  9. Having myself bought an Apollo spa I can tell you that it lasted me 9 years until I replaced it with an Arctic spa. In the 9 years that I had the Apollo spa the only items that needed to be replaced was the control pack after 5 years, and the pump that lasted me for 7 years. They are excellent built spas and cost less than the Arctic Glacier that replaced it. The reason why I went with Arctic is that I liked the Onzen system. Once you have understood how the system operates it is a breeze to maintain. I have had my Arctic Glacier, which I bought from Apollo in Spokane for about a year and both my wife and I use the hot tub about 3 times a week. We both use the spa every weekend morning to get the day started.
  10. Nigel I have an Arctic Glarier that I got in July 2008. In January about 2 weeks after I changed water it quit producing chlorine. Because of a bad winter with about 100 inches of snow and cold temperatures I waited until later April until i called the dealership to get the tub serviced. A serviced technician came out checked to make sure that the Onzen light on the generator was working and there were bubbles appearing, but I had no puff of smoke comming out. He then checked to make sure that there was voltage going to the electrodes. The dealer had no spare electrodes so I waited 5 weeks until they received the part. They also ionformed me that they have seen lots of failuers in the electrodes and that the parts that they are now getting from Arctic look different. The dealer replaced the part late thursday afternoon while I was at work but the service technician called me before he arrived to let me know what he would be doing. Service technician had to drain the tun to replace the part. When I go home I filled the tub with water and by 8:45PM the tomperature was 88 degrees so I added the salt and then fired up the Onzen. Check it in the morning and had plenty of Chlorine. I bet that they find the electrodes had failed in your tub.
  11. Dust Could you provide us the following. 1. How many times do you and you wife soak in the tub in a week? 2. How much Arctic Refresh do you use after each soak etc. 3. The totel length of your daily filtration cycle 4.The model of the Arctic tub 5. and most import how many Parts Per Million of salt do you have in the water
  12. The latest snow storm in Spokane dumped 24 inches of snow. I had removed 9 inches before I went to bed and then the next morining the picture belowsays it all. This is how much snow that was deposited over night. The tub lid has been closed all week and the Onzen system is making chlorine and the levels were right when I checked it today This morning at 7AM both my wife and I enjoyed the hot tub at a bone chilling temperature of -12 below zero. Life doesn't get any better. My Arctic tub in the snow
  13. Pete, Do you have a test strip that can test the PPM of Sodim Chloride ( salt ) in your water? Also to check for the little cloud of water go through the advaced setting again and once the system resets you should see that cloud in a minute or 2. Chuck
  14. I too have had nothing but a headache with my Arctic Yukon with the Onzen system. I purchased it in August and have had to change the water once a month (even though my wife and I only use it about 3 x a week). I have gone through 4 buckets of sodium bromide salt, countless bottles of Refresh and 4 complete water changes!!!!!!! I am thoroughly disappointed with this product. I have a $12,000 tub in my back yard that goes green within a week after a water change. I have left messages with the service department and I'm still waiting to hear back about a service call. The system is producing lots of bubbles as it should but zero sanatizer. My CP level is set to 3 and I only get an ORP reading of 150, no measureable amount of bromine is being produced. Any suggestions Tom? Looks to me like the Onzen system is bad. I bet it's not producing any ozone which is probably why you are not getting any sanatizer. My Glacier Signature is working great since I b ought it this last July. Just got back from spending 7 days in Mexico and the sanatizer levels was where it should be. Have you been in contact with your dealer service department and what are they saying? Chuck
  15. After reading the forum I understand to get the Onzen system to work all the time you have the following set: CC=0 CF=0 FC=1 Is this true on all tubs with Onzen? My Arctic Glacier had the following settings: CC=0 CF=1 FC=1 I changed CF to CF=0. Does anybody know what each of setting above do individually? Would be nice if Arctic included an explaination and default setting in the Onzen user manual.
