I know this post was some time ago and I hope I can still help.
With such a large pool the first thing I would ask is does this happen all season or more towards the beginning.
Assuming it's happining all year and being as you have replace everything on you Polaris, it's all point toward lack of pressure.
The operating pressure of a Polaris coming off a booster pump should be around 30 PSI. You may be able to purchase a wall tester from your retailer or go to Polaris' web site.
The simple stuff to check before doing that would of course be:
Backwash your filter and check to see if the cleaner works any better.
If not there may be an obstruction in you impeller, filter, chlorinator.
When was the last time the filter was inspected?? In our area a pool of this size would be quite old. Are you putting chlorine "pucks" in the skimmer?? If so you may have some calcification issues in you filter which would give you above normal pressure reading.
Unless you have channeling issues in your filterwhich would do the opposite and give you a lower pressure reading & you pool would be tough to keep clear.
Hope this helps.
