homerandpooh
24 -
Contact Methods
http://
Gender
just north of Baltimore
homerandpooh's Achievements
Disable Heat/low Temp Jacuzzi
homerandpooh replied to homerandpooh's topic in Portable Hot Tubs & Spas
The lowest setting is 80 degrees. I do not have any pool experience, is that comparable to pool temps? I considered just turning off power to the tub. Turning power back on twice a week to run the pumps. I would still perform my chemical maintenance as needed. -
I was hoping to use my spa as a mini pool this summer and would like to disable the heater and the low temp alarm. Anyone know how I can do this? 2007 Jacuzzi J480 jumpers set on board for 60 amp service/heat and pumps work at the same time.
Jacuzzi 480/470 Spa Cover And Lifter
homerandpooh replied to euphoriajet's topic in Portable Hot Tubs & Spas
Just a note, we have a 480 and our cover fits OK, not good not great but OK. The sides don't come down as much as they do in the pic posted earlier in this thread. The area where the cover hinges leaks steam. We added a *solar cover to create a better seal against the shell. No steam leaks now. Basically it seems to me that the whole cover is slightly undersized, maybe by a 1/2 inch on all sides. You can push down on the cover at the higher end of the tub and feel that it isn't making contact with the shell. Perhaps I have a cover made on a Monday, or maybe it's just designed wrong. *- solar cover, not applicable under the cover or where prohibited. -
Spa Thermal Blanket, Is It Worth The Effort?
homerandpooh replied to Nat's topic in Portable Hot Tubs & Spas
We use a "solar blanket" on our spa. It has nothing to do with solar energy or solar anything, it's just bubble wrap. The reason we use it is that our lid has a considerable gap on both sides where it hinges. The 1st cold night we had the spa we noticed steam pouring from these gaps. We purchased a solar cover that actually covers the whole top. We stretch it over the top and then lower the lid. The lid holds it in place and seals against the shell. No more steam leakage. I also think that this will help to prolong the life of my lid as vapors are getting to the underside. As far as chems I have had problems dialing in the Chlorine/Bromine levels and getting the Ph right, but I attributed this to inexperience having only had the spa for a little over a month. I guess it could be the solar cover. Come summer when I won't need it we'll see. Jacuzzi J-480 -
Free Warranty Extension For Spas
homerandpooh replied to diamondg's topic in Portable Hot Tubs & Spas
I paid cash for mine, will the Fed extend my warranty for me? -
Did that price include tax ? $10,500.00 was for the spa, steps, start up chems and delivery. Tax was extra, 5% here in MD. I've learned through the internet that things cost differently throughout the country, why I don't know but they do. Maybe it's delivery surcharges from California where the spa was made.
I don't know if this helps but we just bought a 2007 J480 with no stereo and no ozone for $10,500 in Maryland back in November. So far we have had some minor issues with the spa: There was a "leak" of one of the air intake ports, apparently it had fallen loose during shipping. see thread: http://www.poolspaforum.com/forum/index.ph...c=10065&hl= The top doesn't actually seat itself on the rim of the spa, the area where the lid hinges leaked steam like the smoke stacks on the Titanic. We added one of those "solar" spa covers between the lid and the spa and now no heat escapes from under the lid. The installers failed to set our jumpers for the 60amp service so we didn't know why we couldn't have heat with both pumps on. After reading the manual I figured it out. This is not a manufacturer issue but something that you should know. The jets turn themselves off very easily. You can manually turn them to adjust the amount of flow but they are loose enough that every time you get in you have to "re-open" them. I would like it better if they were a little more stiffer in their turning. All in all I would say that we do like the spa, it was the only one we found with both a lounger and foot dome. The minor problems that we have had have been just that, minor. But this is a NEW tub, in my opinion there shouldn't be any problems with a product from a 50 year old company. Hopefully you'll experience none of what we did and if you do, now you know how we handled them. Happy Soaking.
No matter how high I set the temp, 102,103 or 104 when I check it it's at 101. Granted, it is harder for it to heat while we are using it but when I took the cover off of it earlier it should have been at 103, since I set it there a day before (we were planning on getting in but didn't and I never changed the temp). While in it last night the "heating" symbol was on the display, the temp was set at 103 but it never climbed past 101. Jacuzzi 480 60amp service with the jumpers set for heat/2 pumps.
That's an idea. Certainly a lot less expensive than the heated ones. I think it would prevent ice accumulation, but my concern would be how to shovel snow off of it. Wouldn't the shovel just keep getting "stuck" on it? Maybe a loose shoveling, then use a broom for the remainder? David Black ice and snow are 2 different things. Snow on that mat proabably wouldn't be slippery, snow in general isn't slippery. Hopefully the water would pass through so that it wouldn't ice up. Whatever you decide on, let us know. I may do the same.
This is something I was thinking of as well. We will be walking on a wooden deck back in to our house as well. How about something like this: http://www.matsmatsmats.com/commercial-ind...k-step-mat.html
Brand New Spa, And Its Leaking. Pics, Please Help!
On another note. That night after the installation of the spa/electrical hook up we tested all the spas features. Everything worked as expected. I reset the clock and went to the store. When we left, the spa's water temperature was in the low 60's. When we got home, about 2 hours later, we went outside to see how much the temp had climbed. The new temp was in the mid 70's. Ok, we went back in and eventually went to bed. The next morning I went outside eager to see the temp on our new spa. Well imagine my suprise, it wasn't on, the GFCI disconnect breaker had tripped. No time to fool with it now, I have an hour drive to get to work. When I got home I went straight for the yard. I flipped the breaker from off to on only to have it trip instantly. I logged on here and started reading. I knew that I didn't have a wire problem or a moisture problem. The tub had run perfectly the day before so I knew it wasn't a current draw problem. After reading a post on here about disconnecting the load neutral I gave that a try. I hit the juice and the spa kicked to life. I guessed that this was a sign of a bad GFCI. I left the load neutral unplugged and enjoyed my "brand new-11K-had it 2 days and haven't used it yet-spa." When I got home the next day I replaced the GFCI, reconnected the load neutral and fired it up. This was yesterday and when I got home today, she was still on. Great success! The moral: never assume the crap you buy isn't crap -
Does that upper piece sit directly below an 'air' valve lever on the spa topside? If so does the valve properly allow and shut off air to the corresponding jet? Some do sit above the water-line, but they use check valves to prevent leaking. The one on your tub sure looks like it should be connected to the upper piece. No it does not sit below an air vent. It's some kind of air check valve. When it needs air it sucks inward pulling the black baffle in. When not, the pressure of the water is supposed to push it back sealing it off. I guess by being below the water line it couldn't handle the amount of water/pressure and that made it drip. The leak wasn't overwhelming but a leak none-the-less. I was more concerned about the potential damage to the insullation and general interior area then the amout of water lost. -
Service guy came out today. They said "that this is the intake for the air system and it must have fallen loose because it was below the water line and that my water level was too high. He afixed it higher up in the cabinet, thus placing it above the water line." Ok, this is what they've told me over the phone, I haven't made it out there to see exactly what he did yet, hopefully that's what it was. I filled my tub to just above the highest jet/below the head rest - as per instructions-. I didn't have it filled too high. -
Jacuzzi 480 Location is under the waterfall side. A 3/4 tubing that has a white plastic connector on it, its dripping(overflowing) from here. There is a matching "connector" above, it doesn't look like they should be connected, but I don't know. It leaks with nothing running. We noticed it after fill up and before we started it. I called for service and I'm waiting for them to call me back. Here are pics of what is leaking.
My spa is about a month away and I'm trying to do some of the electtical set-up stuff on my own to save money. The dealer recommended 60 amps so that we can run both pumps and the heater. Here is what I plan on doing: installing the pvc conduit with pull string mounting the disconnect 5' from the tub locale running the liquid tight from the disconnect to the tub area with pull string My hope is that the electrician can just show up, run the wire and hook it all up. My questions are 1. did I buy the right disconnect? I bought a 60 amp gfci breaker box ( it's called a spa package from Lowes) I think it has to be 60 amps at the main panel, but does the box outside have to be 60 as well? here's a link to what I bought: http://www.lowes.com/lowes/lkn?action=prod...63-UG412RMW260P 2. is there a limit to the length of the liquid tight I can run? If so I'll have to run more pvc to a box closer then liquid tight from it 3. should I buy and pre run the wire? if so how would I find out which guage, for both the main run and the run to the tub? from the main panel to the disconnect it's about 50' It's a Jacuzzi 480, and we live north of Baltimore where it does get pretty cold in winter. I plan on using a certified electrician to do the hook ups, but if I can run some of the stuff myself I can save money on labor and possible mark-up.
