All Activity
- Today
The good news - the buss fuses measured ok. the Bad news - now the 50 Amp GFI trips whenever I try to turn on the power. Something must be shorting out. I think I’m in for a long ride. any and all ideas welcome.
I’ve been having a guy named, Phil, at Easy Spa Parts in Oceanside,Ca send me spa covers for about the past 10 years and I’ve been very happy as they’ve been as good as the OEM covers. think they have a web site easyspaparts.com .
Tocsdol joined the community
Flixfox changed their profile photo
Flixfox joined the community
- Yesterday
Darren Stalder joined the community
My Balboa VS501Z is not heating the water. The pump is working just fine and the filter is clean. The heater is 5.5Kw 800 15in 2x2 M7 Stud. I've tested all the locations mentioned in https://www.youtube.com/watch?v=GJaHPz75qJU and https://www.balboawatergroup.com/getdoc.cfm?id=1808. And I've got 240v across the black and the red L1 and L2. I've got 243v across the two copper leads going into the heater. All of this is when the heat light is on. I've tested all three fuses and they all have connectivity. How to figure out if it's the circuit board or the heater that has failed? My guess would the heater but that's just speculation. Hopefully this post works since I've repeatedly failed the "prove you're not a bot" questions on sign-up. The sign-up disagree on what day follows Tuesday, how many hours there are in a day, and what the third letter of 'letter' is. Please mods, be kind. -Darren
Cao joined the community
mag040 joined the community
- Last week
I figured out the issue!! The red wire from the flow sensor had gotten slightly pulled out of the sensor bar on the control panel. After resetting it to where it is making contact with the pin, the tub is now heating and throwing only the cool code (water temp is 56°). Thank you for the help.
Sunset Spas Pace, FL 1998 Tub need filter type
cranbiz replied to JPew's topic in Portable Hot Tubs & Spas
Pictures of the filter area would be helpful. -
The Cover Guy is one that gets mentioned here a lot.
I’ll try the Buss fuses today. Pump/heater does not run at all. i believe the incoming power is ok, but given the power surge, that is certainly worth checking.
Coleman (Maax) 461 OHH error.
CanadianSpaTech replied to AlaninTx's topic in Portable Hot Tubs & Spas
Test the 2 green buss fuses that say SC25 or SC 30 on them. Does the heating/filtering related pump run in low or the circ pump if it has one? Test the incoming power and make sure you have 240V red to black and did not lose a leg in the gfci when it took the hit. -
Did you install the new flow switch in the right direction? When the circ is running the toggle in the flow switch should get pushed up against the post making a connection. Verify that it is making the connection. if it is making the connection but you still have a flo error you could try to jumper the flow switch but you will need to verify that the circ is flowing water.. or disconnect the heater from the board for testing so if the heater engages and there is a flow issue it won't go nuclear (only takes a split second to get really hot). I recommend disconnecting the heater for testing. Is the new circ the same voltage as the original? (120V or 240V) Next I would be looking at and testing the sensors. See page 55 below for resistance chart You might find help here: http://jacuzzipartners.com/knowledgelibrary/assets/pdf/681.pdf
CmyHOG joined the community
GregPrice10 joined the community
I have a 2002 Sundance Altamar that I got from a customer of mine. I replaced the circulation pump before I even turned on the tub. I start the tub for the first time and I am getting a FLO code. Here is what I have done, I’ve made sure to the best of my knowledge bled all the air from the system, I have removed the main filter, and I have replaced the flow sensor. Nothing has been able to remove the FLO code. It is flashing the FLO code between the water, temp, and cool signs. The other two pumps and the circulation pump work like they are supposed to and seem to run fine. I am asking on here before I decide to call a service tech.
AlaninTx joined the community
We had a power surge last night and when I went to use my hot tub (about a 2007 Coleman (Maax) 461 with Balboa electronics, it read “STU” (motor stuck?). As usual, first troubleshooting step - power off and power on. That replaced the message with “HOT” (something overheated?). Everything was nice and cool, so I powered it off, moved A1 up to test mode, powered it on and got “OHH” (Overheat?) , which is where it now sits. Kind of strange as it happened in the middle of the night with the tub in standby on a 40° F night. I just started researching it, but figured I’d reach out and see if anybody has the “magic bullet” (not the food processor). I took a pic of the Balboa circuit board if that helps. Thanks, in advance, to anybody that can get me a couple more nice nights in the tub, before the brutal Texas summer rolls in. All thoughts and opinions welcome! Thanks!
Hello, I have a Coleman Saluspa. Pump is always on to keep the water warm. But the pump is making a humming noise, particularly strong if you are far away (50ft) due to the low frequency noise. The spa is on a concrete, in a corner consisting of a wall and a wood fence. The pump is on a thick rubber mat to absorb vibrations. But the pump still makes a loud humming noise that propagates to the neighbor's houses. Any suggestion to isolate the noise? Could I build some kind of a box using plywood + foam and put the pump inside it?
jackoup joined the community
JPew started following Sunset Spas Pace, FL 1998 Tub need filter type
Hello, We inherited a spa with a new house and it works but doesn't have a filter. The manufacturer on the tag is Sunset Spas and they appear to be out of business. Were they ever doing business under another name that I could search for the filter type with? They don't come up in any searches that I can do for filters by manufacturer. Thanks for any help!!
JPew joined the community
waterbear started following Pump help please
Pump bearings and seals wear out and are normal replacement parts. Pumps are either full rated or uprated. Up rating is a marketing ploy using a sneakly little number called the service factor to make it seem your pump is more powerful than it is. (HP rating x service factor = brake HP) Since you didn't give us the model number of your Hayward pump I don't know which yours is. However an uprated 1.5 HP pump will have the same brake HP as a 1 HP full rated model (Full rated pumps use a service factor of 1..and a full rated 1.5 HP pump is the same as a 2 HP uprated model. As to whether you need more HP for your solar heating, is it working properly now or have you had an appreciable pressure drop when you installed it? You might want to look into a variable speed pump and increase your brake HP a bit so you have some reserve in case you need it when the solar is on and run at a lower speed if you are bypassing it. This will save you quite a bit on electrical power in the long run and you will also get better filtration running at a lower speed.
Revid started following Hot tub jets
Sides and floor are 1 1/2” cedar. Just want some bubbling in water to mix hot and cold water up plus bubbles makes it look nicer lol.I put about 30-34 inches of water and it takes aprox 6 hrs to raise temp from 6 to 38 degrees . Ps: grandson trying it out to see if it fits him. Lol
Biodesign Pools not holding chlorine
PennyRealtor replied to Reynbob's topic in Swimming Pool Water Chemistry
What happened with this pool? I am thinking of getting a bio design pool in Georgia -
Hi, I had to replace the main board. After consulting with a local technician we came to conclusion this was due to the thunderstorm I few nights before. Quite normal defect after current spikes in the grid. good luck
@ydragos Please start your own post and describe your issue and post pics of the circuit board and schematic on inside cover
I’m looking for help on a new above ground pool pump. We had a 1.5hp 2 speed Hayward pump that was working well. A few years ago we installed 25 -12ftx2ft solar panels on our 2 storey garage. However our yard is tiered and the garage is on lower level. Pool is on higher level. Pump is on far side of pool so has to run through tubing all around 21 ft x 54” pool then up about 10ft to garage roof. The pump we had was working well for a couple years but last year started sounding louder so we took it in and they said it had a bad bearing. Quoted us same price of a new one to fix. So here we are looking for a replacement. My question is do we need something else? Did we wreck it since we added the solar panels? It would run on low and heat that pool in a few days. If ran on high it wouldn’t heat as it ran through the panels to fast. But i don’t want to buy something underpowered either? All this talk of head pressure etc is over my head. 🙈 I have tried to understand
- Earlier
did you figure it out? I have the same issue
Swhitney started following Troubleshooting Issues with an Older Caldera Hot Tub
I recently acquired an older Caldera hot tub, and unsurprisingly, it came with some issues given its age (2008). Every other day, it displays four flashing lights on the control screen, rendering it inaccessible until I reset the power. Despite replacing the filter, circulation pump, and pressure switch, the problem persists. I suspect the temperature sensor may be inaccurate, but I'm unsure of the next steps.
Supporting hot tob in air any suggestions?
CanadianSpaTech replied to BulletProofer's topic in Portable Hot Tubs & Spas
yes
