Hot Spring Wiring - Portable Hot Tubs & Spas - Pool and Spa Forum
(January 9, 2015) POOLSPAFORUM.COM SITE UPGRADE!
Hot Spring Wiring
  • Please log in to reply
2 replies to this topic
#1 bams10
bams10
    Junior Member
  • Members
  • PipPip
  • 13 posts
Posted 27 August 2007 - 03:56 AM
Hi.
Made my choice on a hot tub,Hot Spring Sovereign.I plan on doing the wiring myself.
On the wiring schematic it shows 50amp 8Awg wire from main service to suppled subpanel.The location of my subpanel will be about 30'from main service.At Lowe's they have a chart showing 50amp needs 6AWG.Could Hot Spring be using 8/g instead of 6/g because their spas draw 230 volts instead of 240v.My thinking is be safe go with 6/g wire.Would that be overkill using 6/g?.
#2 Brulan1
Brulan1
    Spa Guru
  • Members
  • PipPipPipPipPip
  • 1,379 posts
Posted 27 August 2007 - 03:57 AM
QUOTE(bams10 @ Aug 27 2007, 07:56 AM) View Post
Hi.
No 6 gauge I think should be standard. 2 positives, 1 ground, 1 neutrel. 4 wire
#3 dave nh
dave nh
    Spa Savant
  • Members
  • PipPipPip
  • 134 posts
Posted 27 August 2007 - 04:25 AM
If you are going to use romex cable indoors for the run to the disconnect you should go with 6 gauge, the diagram might indicate you are using 4 indiviual 8 gauge wires in couduit. You have to bump the size up if you use the cable due to reqd. temp. derating of the cable.
website security
