terrie Posted March 18, 2006 Report Posted March 18, 2006 happy bottom, easy bottom, gorrilla pad, rhino guard Does any body have experience with any of these products. I am placing it under a legacy 21'ft portable pool. I previously used 1/2" pink insulation foam under a intex frame pool. it worked pretty well. Terrie Quote
sharkman009 Posted March 20, 2006 Report Posted March 20, 2006 happy bottom, easy bottom, gorrilla pad, rhino guard Does any body have experience with any of these products. I am placing it under a legacy 21'ft portable pool. I previously used 1/2" pink insulation foam under a intex frame pool. it worked pretty well. Terrie Yes we use Happy Bottom. It comes in a roll 4' wide and you roll it out and tape the seams together then cut it to the shape that you want. When your done flip it over so that the tape is down on the ground. It is not as thick as what you used before but if you want you can double up on it. Quote
gwrace Posted March 23, 2006 Report Posted March 23, 2006 Yes we use Happy Bottom. It comes in a roll 4' wide and you roll it out and tape the seams together then cut it to the shape that you want. When your done flip it over so that the tape is down on the ground. It is not as thick as what you used before but if you want you can double up on it. We used a Gladon Perfect Bottom on our 33' round Artesian pool to make sure we had a perfectly smooth foot print free bottom. It also protects the liner from roots, nutgrass and insects getting to the liner. We are very pleased with the results even though it was expensive to buy. Quote
Josh-FDL Posted April 4, 2006 Report Posted April 4, 2006 Gladon makes both products, Happy Bottom and Perfect Bottom. I much prefer to use the Perfect Bottom becuase it truly will protect the liner and unlike Happy Bottom it doesn't compress after a few years. Quote
terrie Posted April 8, 2006 Author Report Posted April 8, 2006 how thick is the perfect bottom? Quote
Josh-FDL Posted April 9, 2006 Report Posted April 9, 2006 Perfect Bottom is 30 mil thick. To look at it, it is thinner than happy bottom but it's much, much stronger. Happy Bottom is foam so nut grass, rock, etc can poke through it. Perfect Bottom is a hard plastic sheet. Quote
terrie Posted April 10, 2006 Author Report Posted April 10, 2006 I decided to put a layer of perfect bottom and then happy bottom. overkill probably. i'll let the readers know. Quote
