Guest Tim Posted September 22, 2005 Report Posted September 22, 2005 The other day I went to check on the Spa and noticed a brown foam scum line along the water line in the Spa. It was like pine tar when I tried to remove it. About 2 months ago we switched to soft soak. Test strips looked good once a week when water was tested. What causes this problem and how to fix it is my question. I've seen this problem refered to, but there seems to be a difference of answers to this issue. Thank you for any answers to this question. Quote
Guest r Posted September 22, 2005 Report Posted September 22, 2005 its the sanitizer and PH. When the PH is high, and the sanitizer is high, it clumps. I had the same problem. Adjust the PH and keep the sanitizer within normal range. Good luck. Quote
Guest hottub.pool_boy Posted September 22, 2005 Report Posted September 22, 2005 welcome to one of cons of non-chlorine. try cutting back on your dosages, especially if your running slightly on the high side of tolerances. Quote
