(May 1, 2013) POOLSPAFORUM.COM SITE UPGRADE!
Members, We are in the beginning stages of a major site upgrade to maximize your online experience.  This includes new content, special reports, mobile connectivity, etc. We've even adding several new layers to protection to help insulate the forum from hackers and spammer attacks that are constantly a challenge.  Thank you and we appreciate your loyalty to the best community on the web!
White Foam Problem
  • Please log in to reply
6 replies to this topic
#1 Jerry123
Jerry123
    Junior Member
  • Members
  • PipPip
  • 11 posts
Posted 17 February 2006 - 06:49 AM
I use bromine for a sanitizer and baking soda for alkalinity increaser. I have Liesure time test strips which indicate everything is normal. The one exception here is that I have a Bromine level in the "normal" range even though i have an ozone generator and only a "presence" of bromine is necessary.
First, let me say that my water is crystal clear with no foul odors.
Now....when i use the pumps on high speed, a white foam is generated, open up the air pump and i get more foam, like a big cappucino. If i shut the pumps down the foam immediately dissapates from the surface but the water remains cloudy for a few minutes. Liesuretime "foam down" has some positive effect but not completely. I also rtied the enzyme liquid because it is supposed to dissapate body oils which i figure must be encapsulating air in the water.
Any ideas?
Thanks much.
#2 Brulan1
Brulan1
    Spa Guru
  • Members
  • PipPipPipPipPip
  • 1,379 posts
Posted 17 February 2006 - 08:02 AM
QUOTE(Jerry123 @ Feb 17 2006, 09:49 AM) View Post
Any ideas?
Thanks much.
Try letting the scum bug or scum ball float around in the spa to pick up remenents. Its from shampoos, gels, ect... Use less foam out as well. I have found that Super Blue clarifier by Robarb works extremely well but only a little bit/.
#3 wantaspa
wantaspa
    Junior Member
  • Members
  • PipPip
  • 15 posts
Posted 17 February 2006 - 01:14 PM
Jerry123
I use occasional chorine crystals with built in ozonator and I add chlorine usually after use. To keep water clear, I use 3 chemicals during the week. mondays about 1-2oz of bright and clear (leisurtime), on Wed about 1-2 oz of defender (leisuretime), and on Friday's about 1 oz of enzyme (leisuretime). I was not doing the enzyme for a period of time and noticed the same condition you mention. I would have to use a foam down with every use. After using the enzyme for about 3 weeks now, I have noticed very little foam, and have been able to stop using the foam down.
#4 Brulan1
Brulan1
    Spa Guru
  • Members
  • PipPipPipPipPip
  • 1,379 posts
Posted 17 February 2006 - 01:39 PM
[quote name='wantaspa' date='Feb 17 2006, 04:14 PM' post='4420']
Jerry123
Just take a shower before every use if possible to prevent further foam in the future
#5 Jerry123
Jerry123
    Junior Member
  • Members
  • PipPip
  • 11 posts
Posted 17 February 2006 - 04:44 PM
OK, I think I'll try using the Enzyme liquid regularly for awhile and see if it helps. I'd like to avoid showering before going in the tub if i can. Scum ball, scum bug?? Great names!! Definately gonna get some o' those!!!.
Thanks for your help.
Jerry
#6 Brulan1
Brulan1
    Spa Guru
  • Members
  • PipPipPipPipPip
  • 1,379 posts
Posted 20 February 2006 - 07:30 AM
QUOTE(Jerry123 @ Feb 17 2006, 07:44 PM) View Post
Jerry
#7 Amanda
Amanda
    Amanda
  • Members
  • PipPipPipPip
  • 274 posts
Posted 20 February 2006 - 11:30 AM
There is usually a defaoming agent available at your local spa co. A little of this goes a long way and it's kindof fun to watch it work! You can also turn your jets on for a few minutes till the foam "piles up" and scoop it off the top of the water eliminating most of the source of the bubbles.
You can also get your water tested (or have a spa co. test it for you) for "phosphates". Although not all spa companies test for this. The phosphates is the actual cause of the foam... usually found in detergents n such. There is a number of phosphate removing agents as well so it's more like treating the cause (phosphates) instead of the effect (bubbles/foam).
Amanda
The best intention pales in comparison to the smallest good deed.
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
website security
