How Much De - All Swimming Pools Types - Pool and Spa Forum
(February 26, 2015) POOLSPAFORUM.COM SITE UPGRADE!
How Much De
  • Please log in to reply
9 replies to this topic
#1 jfish
jfish
    Spa Savant
  • Members
  • PipPipPip
  • 61 posts
Posted 30 May 2007 - 05:07 AM
How much DE do I use for my filter? The bag of De says for my filter size I should use 2.5 pounds. The label on the filter says 4.5 pounds. that is a pretty significant difference. Which one is correct? I have been following the filter directions.
#2 valvestem
valvestem
    Junior Member
  • Members
  • PipPip
  • 49 posts
Posted 30 May 2007 - 02:04 PM
I'd use what the filter says. My Hayward takes about 7 coffee cans full of DE. That has always been adequate for good filtration.
#3 jfish
jfish
    Spa Savant
  • Members
  • PipPipPip
  • 61 posts
Posted 31 May 2007 - 11:07 AM
I assume you are referring to a 1 pound coffee can(of which I cannot find anymore, I use a 13 ounce can). I am just wondering about the difference. One way it is 5 one pound cans. The other it is 9 one pound cans. I have been adding 10 thirteen ounce cans. I opened my pool on Sunday and have backwashed and recoated 2 times. The water was pretty clear when it was opened and was sparkling in 24 hours. Would less DE give a longer or shorter time between backwashes
#4 valvestem
valvestem
    Junior Member
  • Members
  • PipPip
  • 49 posts
Posted 20 June 2007 - 03:41 PM
DE filters are not backwashed, just drained flushed and refilled with water, and upon starting recharged with DE. They need service when the pressure can't be brought down for any length of time by bumping the filter. That's why on startup after charging with DE it says to make note of the initial pump pressure. As the filter filters, the pressure will creep up, give it the bump, it will go back to initial pressure. After it won't stay at initial pressure for a time, service. Note startup initial pressure.
My Hayward DE filter says use about 15 1lb. coffee cans full of DE. I have only been using 5 cans at each charge for over 15 years with no problem. My current pool is a 21' above ground, previous pool was a 24' above ground that lasted 18 years.
QUOTE(jfish @ May 31 2007, 03:07 PM) View Post
#5 Jenny
Jenny
    Newbie
  • Members
  • Pip
  • 7 posts
Posted 21 June 2007 - 05:33 PM
Well got into today as well. It did great. I invite some of the neighbors. Had a blast. My chorline level went down to normal. I'm going to shock my pool on Sunday. (properly this time).
Can anyone help me with one last ? (at least I hope its the last one). How do you put the chlorine tablets in the filter. I mean I know where they go and how to insert them but isn't the water going to come out of the pump when I do it that? Is that ok? If someone could let me know. Right now all the PH, Bromine and Chlorine levels are just perfect but I know I will need to do it sometime and in a week need to change the filter. Well thanks for the help. Take care all.
Jenny
#6 Bellafuji
Bellafuji
    Newbie
  • Members
  • Pip
  • 2 posts
Posted 24 May 2009 - 04:18 AM
QUOTE (Jenny @ Jun 21 2007, 09:33 PM) <{POST_SNAPBACK}>
Jenny
Try installing a Shut off vavle on the retun line that goes back into the pool. When you go to install the tablets shut the valve off. This should keep the water from coming back through the filter.
#7 PaulR
PaulR
    Hot Tub Aficionado
  • Members
  • PipPipPipPip
  • 429 posts
Posted 24 May 2009 - 09:11 PM
QUOTE (valvestem @ Jun 20 2007, 04:41 PM) <{POST_SNAPBACK}>
Some DE filters want to be bumped, some want to be backwashed. All should be periodically opened up and scrubbed out. Check your manual.
--paulr
#8 ps558
ps558
    Spa Guru
  • Validating
  • PipPipPipPipPip
  • 1,121 posts
Posted 30 May 2009 - 12:24 PM
Jenny
Put the tablets in the skimmer basket.
#9 PaulR
PaulR
    Hot Tub Aficionado
  • Members
  • PipPipPipPip
  • 429 posts
Posted 01 June 2009 - 12:21 PM
If you run your filter 24/7 it's okay to put tablets in the skimmer basket. I've read people's stories about how they can damage things if they're just sitting there with no water flow, as the tabs are somewhat acidic. You can get a cheap plastic floater for the tabs, works great.
Long-term use of tablets will increase your CYA too much, though, you want to keep an eye on that.
--paulr
#10 Linda23
Linda23
    Junior Member
  • Members
  • PipPip
  • 15 posts
Posted 02 June 2009 - 08:47 AM
QUOTE (ps558 @ May 30 2009, 12:24 PM) <{POST_SNAPBACK}>
Jenny
Years ago a pool dealer gave me one of these. It is called an ez scoop and it is used for DE earth filters. Better than a coffee can and does not cost much at all!
http://www.coolpoold...scoopdecup.aspx
website security
