I noticed water under my tub this morning so I opened the panel and see that it is draining from the shaft of the main pump where it goes into the wet end. I hit the button to turn on the pump itself and I just get a humming noise from the pump but if I get the propeller started with a screwdriver it does start working. So my question is do I need both the motor and the wet end or do you think it could just be one or the other?
