The base of the Dynasty Spa is 2 inches lower than the wooden framework. Is it best to support the spa from the base, or from the framework, or should they both be even? Seems the weight of the water would pull the whole thing inward if its just from the frame. The frame WAS previously supported on 2x10's under the deck, with nothing under the bottom of the spa. Could this cause the whole thing to warp?
