JohnES Posted May 17, 2013 Report Posted May 17, 2013 I am having trouble getting my heater to start this year. It is a Jandy LXi 400 NG The pump is running well so there should be good water flow. When I turn it on the fan starts up, after 10-15 seconds there is a click and the gas turns on (can smell it), a couple of seconds after that it lights and produces strong heat for about 5 seconds and then the heat stops. It does this 2 more times and then gives the standard IGN CONTROL error. I have tried vacuuming out via the access at the top. I played with the air intake adjuster at the side, seems to be in the correct position as if I move it too much either way it doesn't even light . I opened the airbox and unscrewed the brass gas jets (not sure of the correct term). I couldn't get those all the way out but I was able to blow compressed air into them. The heater does this each year but typically starts up after a few tries. This year I cannot get it going. Is there anywhere else I should try cleaning? Thanks, John Quote
Bugman1400 Posted May 20, 2013 Report Posted May 20, 2013 The symptom you describe sounds like a sooted up flame sensor. Find the flame sensor and use an old piece of sand paper or steel wool to clean it off. Quote
jpage4500 Posted May 1, 2022 Report Posted May 1, 2022 Hi @JohnES - this is a very old thread but I'm having the same issue and wondering if you figured out what was wrong? I've read a few similar threads and found a couple of suggestions: - thermal regulator - high limit Quote
