ht2020 Posted May 16, 2013 Report Posted May 16, 2013 On my recent HS Vanguard purchase I was set up with the Nature 2 silver stick/MPS system ie: no or low chlorine recipe. The system is quite easy ie: MPS before and after every soak; shock with dichlor as needed. My only problem with this regimen is that it relies on testing wtih MPS strips to verify that it is being done correctly. Whereas if I use dichlor I can do more accurate testing with a reagent kit (I have the pool master one). Chlorine is easy to test and I suspect that the kits and strips are pretty accurate. Does anyone know if the Zodiac Nature2 MPS strips are accurate? The other thing I can test for with my kit is combined chlorine (test for chlorine first, then wait for 2 minutes and retake the reading to determine the combined chlorine ppm level). I suppose if the combined chlorine is high I can shock as needed. One other issue: I am shocking weekly with 1oz dichlor and have already done this 4 times. Therefore 4oz of dichlor in a 400gallon pool is equivalent to 36 ppm chlorine and 33 ppm CYA. Therefore, this would indicate that I am now ready to switch to 6% bleach for my weekly shock. How much 6% bleach would I need to use to be equivalent to 1 ounce dichlor? My calcs tell me about 8.5oz?? Quote
chem geek Posted May 17, 2013 Report Posted May 17, 2013 The MPS test strips should be OK for their purpose. I'm not aware of reasonably priced drop-based MPS tests except for using the Taylor chlorine tests and then using the K-2042 MPS interference remover to be able to distinguish between chlorine and MPS. 1 ounce weight of Dichlor has the same chlorine content as 8.6 fluid ounces of 6% bleach or 6.25 fluid ounces of 8.25% bleach which is the new standard (Clorox switched last year and most other Ultra bleaches are following). Quote
