g13392 Posted May 7, 2013 Report Posted May 7, 2013 Hello All, I'm sure this issue came up before, but I figured it might be easier to spell out my problem then searching. I have a 2005 Hot Springs Sovereign. I believe there is a pin hole leak somewhere, cause the ground area right under the control panel is always wet. It's not enough to create a puddle, but the area never dries. I think I lose about 1" - 2" of water per week. I went to the local dealer, and they suggested trying Fix a Leak product by Marlig Industries. I removed the filters and added the Fix a Leak per the instruction. After about a week or so, the leak has not stopped, but now the spa is not working. The power LED and the Ready LED are now blinking. I shut the power down for few minutes and turned it back on. After turning the power back on, the power LED is solid red and the Ready LED is not on. After about 30 seconds, both power LED and ready LED are blinking. I tried this several times, but to no avail. I emptied the tub and refilled, and went through the whole power cycle, but same blinking occurs. I measured the two thermistors, and they read16.29k Ohms and 16.80k Ohms. I didn't have a thermometer handy, so I couldn't measure the water teimp, but I just got done filling it with tap water, which could be cold after running for about an hour. I'm assuming around 60 degrees. Does the resistance sound about right? Are they close enough? If it is not the thermistors, what else could I check? How do I check to see if circ pump is working? Any help would be greatly appreciated. Quote
PreservedSwine Posted May 8, 2013 Report Posted May 8, 2013 That's a flow error. Make sure your filters are not clogged. Is the circ pump working? If not, replace it. If it is, OHM out the flow sensor harness coming from the heater. Check, the light, drain caps, and ozone system for leaks. Quote
g13392 Posted May 8, 2013 Author Report Posted May 8, 2013 I removed the circ pump to test it out. I applied 120V to the pump, and nothing happens. I'm assuming the pump should spin, right? I don't need any water pressure to trigger the motor? I'm guessing the pump is shot, and is the culprit. Quote
Spa_Guru Posted May 8, 2013 Report Posted May 8, 2013 If the pump you are testing is about the size of a soda can, it has a floating impeller in it, and it is probably clogged with the fix a leak stuff. It doesn't have a shaft setup like most pumps, pull the impeller and have a look. Quote
PreservedSwine Posted May 9, 2013 Report Posted May 9, 2013 Yes, it should spin. Replace it, and you'll be good to go. Quote
g13392 Posted May 17, 2013 Author Report Posted May 17, 2013 Here is the latest. The new pump came in, plugged it in, and the spa is running great. While I was waiting for the pump to come in, I had all the lines plugged with wine cork (so happy the cork was a perfect fit). I noticed that the area around the hot tub is not wet anymore. I don't think the pump, or any connections in the compartment was leaking cause the floor of the campartment was always dry. So now the spa is running great AND the area under the tub is dry. I'm not sure what the cause was for constant moisture, But we're back in business, and the family is happy. Quote
