QueenQuad Posted April 22, 2013 Report Posted April 22, 2013 I need some serious help and input!!! We have an above ground 16' x 32' Dough-boy pool. The last 3 winters our winter covers (new each year) have ripped and dumped the contents into our pool, forcing us to drain the entire pool and do some serious cleaning from the sludge (leaves and dirt) that fell in it. This year the cover ripped in January, so we are sitting with a half exposed pool since there's really nothing we can do about it for another month when it warms up for pool season. The PROBLEM is the WIND!! We have put water on top of the pool cover, tight clamps on the south side of the pool where it catches the most wind, but this time the north end ripped end to end. Does anyone have any ideas to how we can better keep the wind from thrashing our winter cover all around?? It gets so bad it takes the water right off the top and virtually throws it at the house. I'm at my wits ends as to what to do for next winter, and would really like to have a plan in place before next fall gets here. We've had this pool since 2006 and hasn't been an issue til these last 3 winters and the wind we've had. PLEASE, if anyone has any ideas, please share them with me! Would be much appreciated. Quote
jasmine11 Posted June 28, 2013 Report Posted June 28, 2013 well, after seeing the same relays from spa dealers at around $30 each, i ended up ordering directly from the company that makes them for less than https://www.lpi.org/ http://www.braindumps.com/CCIE.htm http://www.upenn.edu/ http://en.wikipedia.org/wiki/Apple_Inc. Quote
Crusingthecountry Posted September 24, 2013 Report Posted September 24, 2013 Just saw your post and had to laugh!! I gave up on winter covers after 2 years. Same reason! Theyare waste of time and money. My advice:just plan on a little extra spring clean up work!! Quote
Lee12 Posted March 28, 2014 Report Posted March 28, 2014 Yeah, your situation sounds as if it might be better to cut your losses, drain the pool over the winter, and then clean and refill it in the spring. Or you could look into putting something heavy-duty on top of the covers, to try and stop 'em from ripping, something like sheets of wood or something like that... Quote
