Jddavis0009 Posted March 18, 2013 Report Posted March 18, 2013 Does anyone have a list of the soft codes for caldera utopia spas? Dealer only gave me the one to change it to a converted tub. Quote
Dan.The.Spa.Man Posted March 19, 2013 Report Posted March 19, 2013 What model is it? I'm not aware of any of the utopia models being convertible unless you are talking about the Cantabria from 50 to 70 amp. Soft codes for what? Quote
Jddavis0009 Posted March 19, 2013 Author Report Posted March 19, 2013 Yes I'm sorry it is a cantabria. Quote
Dan.The.Spa.Man Posted March 19, 2013 Report Posted March 19, 2013 What are you trying to do with a code? All the soft codes do is turn on or off certain components that may or may not be in a certain tub. Like if a tub has 1,2, or 3 pumps, an air blower, 1 or 2 speed pumps, etc. If you have those components the jumper is set on, if you don't have the component it is turned off. Turning a jumper on if the component isn't installed isn't going to do anything. The Cantabria pretty much has everything installed. Quote
Jddavis0009 Posted March 20, 2013 Author Report Posted March 20, 2013 My dealer said that they can change a lot of things. Length of time pumps run, max temp setting ext. not really trying to do anything special just wanting to know what can be changed in case one appeals to me. Quote
