We have the 94 Soverign. Recently fixed light lens leak and installed new components with Balboa new guts. It works fine but has developed a leak, not sure where. It is not in light lens. It is dry under front where components are located. It does not leak when pump is not on. Looking for suggestions where this year spa might be leaking and how I can troubleshoot to find it. It is a good spa and new parts are great so what to try and keep if I can fix leak? Looking for suggestions. Thanks as always for any help.
If it isn't leaking when the main jet pump is on, the leak is in your suction line.
You are probably in for blocking it up and digging for the leak.
