troytroy Posted March 1, 2013 Report Posted March 1, 2013 hi to all forgive me if i post in the wrong place i am new and could really use some help i have recently got a spa my first one i dont know the make cant seem to identifiy it ? it has a balboa m7 value and balboa 400 top side as soon as i turn on the breaker the spa primes and the the pump runs on low speed the problem is the blower runs all the time if i switch off the blower on the topside it stops and the heater kicks in but aftre about 15 econds the blower fires up again and the heater kicks out so my tub is staying cold heater will only work when blower is off i have triied to run it with the blower unpluged i still have to press the blower button on the top side to make it think the blower is off and the same thing happens i press blower it thinks its off heater lights up 15 seconds or so the control thinks the blower has switched itself back on and the heater light goes off again any help would be really good it has a hydroair gennisis blower model no GB90-2NN-S BALBOA M7 VALUE CONTROL BOARD VL 400 BALBOA TOPSIDE WITH 4 BUTTONS AND DIGITAL DISPLAY BUTTONS ARE SET JETS LIGHT AND BLOWER THANKS IN ADVANCE Quote
Roger Posted March 2, 2013 Report Posted March 2, 2013 hi to all forgive me if i post in the wrong place i am new and could really use some help i have recently got a spa my first one i dont know the make cant seem to identifiy it ? it has a balboa m7 value and balboa 400 top side as soon as i turn on the breaker the spa primes and the the pump runs on low speed the problem is the blower runs all the time if i switch off the blower on the topside it stops and the heater kicks in but aftre about 15 econds the blower fires up again and the heater kicks out so my tub is staying cold heater will only work when blower is off i have triied to run it with the blower unpluged i still have to press the blower button on the top side to make it think the blower is off and the same thing happens i press blower it thinks its off heater lights up 15 seconds or so the control thinks the blower has switched itself back on and the heater light goes off again any help would be really good it has a hydroair gennisis blower model no GB90-2NN-S BALBOA M7 VALUE CONTROL BOARD VL 400 BALBOA TOPSIDE WITH 4 BUTTONS AND DIGITAL DISPLAY BUTTONS ARE SET JETS LIGHT AND BLOWER THANKS IN ADVANCE Sounds like the pack has a problem. That pack is designed to run the blower for 15 seconds at every startup. Quote
