Hi- I recently aquired hotspring prodigy 1997 with the Watkins pump. Did a few things ( changed shaft seal- was leaking, changed outlet thermistor- I tightened too much and cracked it.. etc... I went to start the pump and the small circulation pump is working but the main pump is not. I disconnected the pump wiring from the mother board and connected it to an extension to an outdoor gfi and the pump worked. When connected to the board the pump does not work. Is there a reset or something?
Did you check for fuses?
Voltage at the board?
All breakers going to the spa?
