Not a good idea. Also, a strong acid is completely irrelevant with regard to irritation because when diluted in water it is no different than a weak acid and is even more "pure" (vinegar is acetic acid so adds organics that chlorine reacts with). It takes less quantity of a stronger acid so the product of amount you add and its concentration will be the same regardless of the acid that you use.
