wojie24 Posted February 1, 2013 Report Posted February 1, 2013 Hi all, I have a persistent problem I hope someone can help me with. Last summer (Australia, so around December 2011) I started noticing all our bathing suits were starting to show green stains after a swim. I took a water sample to my local pool shop and the guy tested it for Copper and the reading was quite high so it was decided that this was the problem. I use a 5 in 1 chlorine which has algecide so that is where we thought the copper might have been coming from. I treated the pool (all 70,000 litres of it!) with several bottles of stain remover over a few weeks to remove the copper and the levels dropped to an acceptable level. Even after that treatment, we are still getting green stains! I do not over chlorinate my pool so it can't be that surely? Any ideas why we still get the stains? I have a concrete pool, like i said 70,000 litres, with a sand filter. Any help would be great, cheers. Quote
LegsOnEarth Posted February 7, 2013 Report Posted February 7, 2013 Do you have a heater on your pool? Sounds like you still have copper in the water, and I doubt that the 5in1 is going to be a significant enough amount to cause the problems you're having. Have you had your source water tested as well? Quote
wojie24 Posted February 9, 2013 Author Report Posted February 9, 2013 No heater but we have a solar blanket which keeps the water 30+°C. We have not had the source water tested so I might do that. We have only seen the problem the last 2 years and we have been in the house for over 5 years so if it was the source water surely we would of seen problems before? Quote
Cape Town Pools Posted February 17, 2013 Report Posted February 17, 2013 I don't know if this will help in any way. in South AFrica we have a product called Blu52. From my understanding it is a copper based sanitizer. I have heard from a few users that when they tried using an chlorine shock treatment in conjunction with the product that overnight their pools where often badly stained. I have no idea if this has any relevance to your situation but I hope it helps. Quote
